The ss15 rb20 high flow runs a 63mm turbine which is some thing ive recently made upgrading the ones in the ss2. I didnt think it was wise running a 72mm turbine which is what i usually use in rb25det highflows, as it might be too laggy on the rb20.
Compressor is ss15 67mm, that was tested and perfect for 250rwkws, that is pretty comfortable for this turbine to handle. So should make good power and not too laggy for the road.
The ss2 t28 is due for dyno tomorrow. I will enable vtc also, will post results once complete.
Made 297rwkws on 22psi On pump 98 fuel. Compressor maxed out. Turbine had alot more in it. How ever its gettng too laggy for what i originally wanted and i think i know just why.
Will upload result later on.
Here is the power reading for today.
Peek power of 297rwkws P98 fuel is only at 21psi of boost. How ever 20psi is by 4750 indicate some thing is not right.
After having a closer look, it appears the small T2x turbine housings are not very good taking any thing bigger then a 56mm turbine. As there is no more materials left covering the exducer radius, which just made the inducer gap into the blade height. It worked identically to as if I'm using a huge turbine blade that has a inducer area of some thing of 20mms. That have explains why the GT3071 worked horribly in side a .64 T2x turbine compare to as if it is in a .63 T3x turbine.
Large turbine end have made an very happy engine, taking boost and extra timing no worries.
I'm going to make an customized T3x geometry turbine housing into a T2x print, and re-evaluate using the same chra. Photos will be posted as project progresses.
Thinking of making a turbocharger out of this turbine wheel for my R33:
:w00t: Actually it was for an 1600HP marine engine.
I'm going to try how the .86ar goes on my ss1.5 then
Hopefully still get fullboost by 4-4300rpm and gain 20kw from more timing and boost
Going to install it on the weekend and tune maybe 2-3 weeks as it easter holidays and I'll get a dyno sheet overlaying the atr28g2/ss1.5 64ar and ss1.5 86ar
Interesting times Tao , it's about time someone delved into turbines and housings to unchain us from Garretts aging GT30 turbine variations .
You seem to be using quite large turbines for your compressors Tao , is there any chance of finding and using something a bit lighter and more open bladed like the GT28 turbine only larger and in similar trim sizes ?
Cheers A .
Hello Stao,
Regarding the RB20 SS1.5 Hiflow, just so I have all the figures correct....
You're saying the compressor exducer is 67mm and the inducer is about 50mm?
While the turbine exducer is 63mm and the inducer is 58mm?
What would be the turbine housings A/R .46?
Regards, Graham.
Edited by E-HCR32
Installed the .86ar to my ss1.5 to my sr20det
Definately feels alil doughy in the lower revs compared to the .64 but hopefully retune will make it abit better but abit surprised in fourth gear full boost 20psi by 3900rpm can see the boost rise fast by 3500rpm and full boost just before it reaches 4000rpm
Will book in a retune next week hopefully can fit me in before easter long weekend going put in a fresh set of performace valve springs next weekend and before tune and run it at 25psi
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
