that kia must be a laugh to drive....throw some m/ts on the front and go down the princes highway on a friday night...
cheers
darren
About 1 launch and youd snap something lol
Thought there might be some more interest in this thread,
I'm selling an SS1 I recently purchased for my RB20. Need the cash unfortunately.
http://www.skylinesaustralia.com/forums/topic/441479-sa-hypergear-ss1-turbo-brand-new/
Here my dyno results from my ss1.5 on my sr20det non VCt 180sx
266rwkw ss1.5 .86ar
250rwkw ss1.5 .64ar
251rwkw atr28g2 .64ar
Power vs boost
Power vs torque
Tuner said there was 5-10kw more in it if I replaced my dw300 fuel pump for a walbro 460lph pump as fuel pressure was dropping 10psi under load when tested but not worth the money and extra to tune right now as turbo is at it's max and injectors will be too as I'm on e85
The .86ar did gain 16rwkw but at 250rpm lag penalty and 5psi more down low and 2-3psi more up top
So it did make the engine happier as he could add in lots more timing and more boost
where as before I was capped to 20psi with .64ar or he had to remove lots of timing with more boost to the point power went down with more boost
Any dyno reading from that tune? The SS2 on Jared's car is the Black edition, with the latest compressor and larger turbine. It should be making power easier then the previous version.
A result sent in from an SS1PU customer. This is the latest version also that has a different compressor that is engineered to hold boost better and more top end.
It is running on E85 maxing out fuel pump. Peek of 301rwkws @ 17psi. With plenty of mid range.
From customer's feed back letter:
R34 GTT (Stock Motor)
Supporting Mods
Blitz FMIC Return Flow
1000cc Injectors
Standard Airbox (Panel Filter)
3inch Bellmouth Full Exhaust
Z32 AFM
Walbro 255 Fuel Pump
SS1PU (latest model)
Scotty's Alloy Intake
CALTEX E-Flex
301.8 Rwkw (18psi peak, drops off to 17psi holds well)
Is this internal or external gate. Far out there are so many options haha, and I have the exact same mods and I'm getting it done at pulse racing... May save me some time
Drives a lot nicer now it's tuned to the .86rear
Part throttle still has power but haven't done a lot of driving yet as I just got it tuned
But I was surprised it didn't lose much response going from the .64 to .86 200rpm if they where both on 20psi was expecting it to be worse and laggier about 500rpm but engine is a lot happier
Should have waited alil longer as the atr28ss2 would have been a lot better everywhere and make more power down low and up top
This is an internally gated bolton upgrade turbo that sits on factory manifold, dump, and water lines. It is an very responsive turbo for around the 260rwkws mark on P98 fuel. Alternatively you can run the new SS2 which would be good enough for 300rwkws on pump 98 fuel.
I'm missing something - I think his is on E85 and it maxed out making just over 260rwkw? Or you mean 300kw @ hubs?
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
