that kia must be a laugh to drive....throw some m/ts on the front and go down the princes highway on a friday night...
cheers
darren
About 1 launch and youd snap something lol
Thought there might be some more interest in this thread,
I'm selling an SS1 I recently purchased for my RB20. Need the cash unfortunately.
http://www.skylinesaustralia.com/forums/topic/441479-sa-hypergear-ss1-turbo-brand-new/
Here my dyno results from my ss1.5 on my sr20det non VCt 180sx
266rwkw ss1.5 .86ar
250rwkw ss1.5 .64ar
251rwkw atr28g2 .64ar
Power vs boost
Power vs torque
Tuner said there was 5-10kw more in it if I replaced my dw300 fuel pump for a walbro 460lph pump as fuel pressure was dropping 10psi under load when tested but not worth the money and extra to tune right now as turbo is at it's max and injectors will be too as I'm on e85
The .86ar did gain 16rwkw but at 250rpm lag penalty and 5psi more down low and 2-3psi more up top
So it did make the engine happier as he could add in lots more timing and more boost
where as before I was capped to 20psi with .64ar or he had to remove lots of timing with more boost to the point power went down with more boost
Any dyno reading from that tune? The SS2 on Jared's car is the Black edition, with the latest compressor and larger turbine. It should be making power easier then the previous version.
A result sent in from an SS1PU customer. This is the latest version also that has a different compressor that is engineered to hold boost better and more top end.
It is running on E85 maxing out fuel pump. Peek of 301rwkws @ 17psi. With plenty of mid range.
From customer's feed back letter:
R34 GTT (Stock Motor)
Supporting Mods
Blitz FMIC Return Flow
1000cc Injectors
Standard Airbox (Panel Filter)
3inch Bellmouth Full Exhaust
Z32 AFM
Walbro 255 Fuel Pump
SS1PU (latest model)
Scotty's Alloy Intake
CALTEX E-Flex
301.8 Rwkw (18psi peak, drops off to 17psi holds well)
Is this internal or external gate. Far out there are so many options haha, and I have the exact same mods and I'm getting it done at pulse racing... May save me some time
Drives a lot nicer now it's tuned to the .86rear
Part throttle still has power but haven't done a lot of driving yet as I just got it tuned
But I was surprised it didn't lose much response going from the .64 to .86 200rpm if they where both on 20psi was expecting it to be worse and laggier about 500rpm but engine is a lot happier
Should have waited alil longer as the atr28ss2 would have been a lot better everywhere and make more power down low and up top
This is an internally gated bolton upgrade turbo that sits on factory manifold, dump, and water lines. It is an very responsive turbo for around the 260rwkws mark on P98 fuel. Alternatively you can run the new SS2 which would be good enough for 300rwkws on pump 98 fuel.
I'm missing something - I think his is on E85 and it maxed out making just over 260rwkw? Or you mean 300kw @ hubs?
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
