hypergear Posted April 23, 2014 Author Share Posted April 23, 2014 sr can be very different depending on cams. On this particular car yes. But either way they all made more power and way better response then the td05H 18g copy that was originally on there. Car was tuned on a roller dyno with proper configurations. it still runs off stock 2.5inches induction. I have a feeling it might be restrictive. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7264996 Share on other sites More sharing options...
hy_rpm Posted April 23, 2014 Share Posted April 23, 2014 Will see how the atr28ss2 does on my brothers s13 on pump 98 If that goes well I might be intrested in upgrading Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265050 Share on other sites More sharing options...
PN-Mad Posted April 23, 2014 Share Posted April 23, 2014 While we are on Sr results, I can't remember if I shared this in here or not. Rps13 S14 motor, with VCT active. Gtx3071 0.82, 6boost, 44mm tial, un1cams. Boosts are 16/18psi Stock motor, incl head gasket, and it's on p98. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265069 Share on other sites More sharing options...
Lithium Posted April 24, 2014 Share Posted April 24, 2014 ^ Nice, GTScoTT may sex wee! Would be a little meaningful with rpm though, silly rolling road dynos On 23/04/2014 at 11:29 PM, hy_rpm said: Will see how the atr28ss2 does on my brothers s13 on pump 98If that goes well I might be intrested in upgrading I'm curious - I notice the 18G and your current turbo made almost exactly the power, and you mentioned previously you had full boost by 4000rpm with the 18G.... how does the .86 compare with the 18G in terms of response? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265078 Share on other sites More sharing options...
PN-Mad Posted April 24, 2014 Share Posted April 24, 2014 On 24/04/2014 at 12:00 AM, Lithium said: ^ Nice, GTScoTT may sex wee! Would be a little meaningful with rpm though, silly rolling road dynos I'm curious - I notice the 18G and your current turbo made almost exactly the power, and you mentioned previously you had full boost by 4000rpm with the 18G.... how does the .86 compare with the 18G in terms of response? Yup, Scott and I have been chatting away about setups... We only revved it to about 7300rpm if that helps. It's not too laggy, but it does catch me out now and then on the track getting out of corners. It's mainly a track car. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265158 Share on other sites More sharing options...
hy_rpm Posted April 24, 2014 Share Posted April 24, 2014 It's feels as with the 18g it was a big surge of power after 4000rpm And not much before than Where as with the ss1.5 it just comes in more linear and smoother power delivery from 3000rpm up but there is no big surge of power The way the power comes on with the ss1.5 it will be easier to put down but the 18g snaps you back in the seat more once on power Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265308 Share on other sites More sharing options...
Lithium Posted April 24, 2014 Share Posted April 24, 2014 That'll probably be partly just the boost curve of the 18G going up higher in the midrange as much as anything, though the big a/r you have now probably also plays into it a bit. Would have been interesting to have seen how the 16G6 would have gone, we're making similar power to you with one but it's also in the TD06 sized housing - have suspected for a long time (as Stao referred to with his turbo too) the T28 bolton housing and associated bits are probably a bit of a restriction at this level. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265316 Share on other sites More sharing options...
hy_rpm Posted April 24, 2014 Share Posted April 24, 2014 Yeah but with the .64ar on it was similar to now just came on alil earlier Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265460 Share on other sites More sharing options...
iruvyouskyrine Posted April 24, 2014 Share Posted April 24, 2014 On 27/03/2014 at 12:34 AM, hypergear said: Another update this is my latest ATR43SS2 turbocharger.Compare to the current one. Compressor inducer has been increased by 2mms, while the turbine inducer and exducer has been increased by 3mms. This particular one is expected to be maxed out at around 390rwkws on E85. Hey Stao, Whats the advantages of the new SS2 ball bearing version over the older journal bearing one? I bought mine mid last year and it is going onto my RB2530 so wondering if its worth getting you to upgrade it while its off. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265617 Share on other sites More sharing options...
hypergear Posted April 24, 2014 Author Share Posted April 24, 2014 The newer version has a larger 63mm turbine and a larger compressor inducer. It will make more power. With the ball bearing part, well it does not make a real lot of differences. Just prettier to look at when I flick it with my fingers. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265683 Share on other sites More sharing options...
iruvyouskyrine Posted April 24, 2014 Share Posted April 24, 2014 I though (have done no research) that a ball bearing turbo would be more responsive than a journal turbo. Especially transient response. Guess I won't worry about it then Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265693 Share on other sites More sharing options...
GTScotT Posted April 24, 2014 Share Posted April 24, 2014 On 24/04/2014 at 7:36 AM, hy_rpm said: Yeah but with the .64ar on it was similar to now just came on alil earlier He's referring to your comp housing. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265867 Share on other sites More sharing options...
hy_rpm Posted April 24, 2014 Share Posted April 24, 2014 I was talking to lithium But the the 2.5 inch comp housing can't be too restrictive as the 180sx before me on the dyno had the 2.5inch bolt on comp housing with the hks2540 and the pulled 280 odd kW and backed it off to 274kw on just 22psi cause the injectors were maxxed and same as a s15 with a greddy t518z made 281kw The atr28ss2 should make Simlar power to the gtx3071r on pump 98 but with less lag The same lag I got now with the ss1.5 but 280 odd kw on pump 98 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265895 Share on other sites More sharing options...
hypergear Posted April 25, 2014 Author Share Posted April 25, 2014 Well, i can run a 2.5inches pipe to it and find out i guess. Either way. Assume if you had enough fuel and has larger size cams, the ss15 should set around the 280rwkws mark on your car. Building one more prototype working with the .64 rear. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265962 Share on other sites More sharing options...
Ben C34 Posted April 25, 2014 Share Posted April 25, 2014 This thread is already hard enough to follow, but now with the sr20 results in thr mix it's super hard. Perhaps there should be a separate sr20 results thread. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7265975 Share on other sites More sharing options...
hy_rpm Posted April 25, 2014 Share Posted April 25, 2014 Yeah tuner did say there was proberly 5-10kw in it if I replaced the fuel pump to a walbro 460lph But I can't justify spending $500 plus for the retune and fuel pump to gain 5-10kw if I was to get a retune I want to gain atleast 20-30kw But I need to upgrade injectors and fuel pump and turbo if I was to stay e85 But if I stayed with p100 100octane fuel I might get away with just a larger pump and the turbo upgrade which will proberly be my next stage in a few months Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7266034 Share on other sites More sharing options...
hy_rpm Posted April 25, 2014 Share Posted April 25, 2014 Look at the precision 5130 sr20det t2 bolt on turbo With 2bolt fr comp cover makes 320kw+ So I'm sure the 2.5inch inlet shouldn't be a restricting flow Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7266044 Share on other sites More sharing options...
hypergear Posted April 25, 2014 Author Share Posted April 25, 2014 The 2.5 inches skyline induction pipe in comparison to a proper 3 inch metal induction pipe was huge in difference. The S14.5 that I currently have also has a 4 inch metal induction pipe. I have seen some 2.5 to 3 inch expander pipe. Those might comes handy. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7266287 Share on other sites More sharing options...
zebra Posted April 26, 2014 Share Posted April 26, 2014 Hey Tao -3 or -4 for the oil feed line on the TD06? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7266618 Share on other sites More sharing options...
zebra Posted April 26, 2014 Share Posted April 26, 2014 Ahh before i forget, the thread sizes for both oil feed and water lines Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/484/#findComment-7266624 Share on other sites More sharing options...
