Manuel Kasko Posted May 9, 2014 Share Posted May 9, 2014 Those figures you are talking about stao is that with E85 or 98? My plan is e85 and 300rwkw so more response the better. I'm guess that would be the 260rwkw one you are taking about? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7278177 Share on other sites More sharing options...
hypergear Posted May 9, 2014 Author Share Posted May 9, 2014 Those are all E85 figures. that would be roughly 260rwkws on P98 fuel. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7278180 Share on other sites More sharing options...
Simon-S14 Posted May 9, 2014 Share Posted May 9, 2014 Massive thanks to Hypergear to assisting me with my turbo issues and rebuilding my 35R to ATR43 specs. I cant wait to drive the car with this! 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7278303 Share on other sites More sharing options...
methz Posted May 10, 2014 Share Posted May 10, 2014 did u figure out why u killed it in the first place? looks the goods Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7278503 Share on other sites More sharing options...
Simon-S14 Posted May 10, 2014 Share Posted May 10, 2014 bearings failed on the garrett Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7278546 Share on other sites More sharing options...
iruvyouskyrine Posted May 11, 2014 Share Posted May 11, 2014 I'm going to assume its gone to SS3 specs? Should have tried his fancy VNT setup. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7279520 Share on other sites More sharing options...
Blackkers Posted May 11, 2014 Share Posted May 11, 2014 how well does the VNT setup work? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7279546 Share on other sites More sharing options...
hypergear Posted May 11, 2014 Author Share Posted May 11, 2014 That above is a ATR43SSG4 core, so similar what it originally was. The VNT system do work and I've been using them a while now for anti lag. This specific method has the potential to knock off about 500RPMs of lag without trading off power. How ever has to be very specific to the amount of back pressure the turbine housing is receiving. Little like setting up Ign timing which at specific point they will allow the engine to output its highest torque while otherwise results the opposite. Some thing worked so well on the RB25det worked horribly on the Kia's High comp G4GC motor. So getting this to work on the Rb30det it will require a new round of research and development. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7279650 Share on other sites More sharing options...
hypergear Posted May 12, 2014 Author Share Posted May 12, 2014 Posting an result. This is from a SS2 Based High flow that we did for a Auto M35 stagea not too long ago. It made 275rwkws on 20psi with Pump 98 fuel. Note: The WOT was engaged in a slow manner on run below, for the reliability of factory Auto. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7280122 Share on other sites More sharing options...
KerrodR33 Posted May 13, 2014 Share Posted May 13, 2014 My SLSS2 turned up today Looks good sitting next to my old highflow paperweight Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7281836 Share on other sites More sharing options...
discopotato03 Posted May 13, 2014 Share Posted May 13, 2014 That pic raises another question Tao , is the compressor housing on your turbo a 0.70 AR T04B one ? The larger ratio B housing is one we don't see too often though I don't know why . It would have a bit more flow capacity than the 0.60AR B housing while being more compact than the T04E or T04S ones . 0.70AR B housings have larger 2.5" (63mm) outlets like 0.70 AR S ones . A . Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7281863 Share on other sites More sharing options...
hypergear Posted May 13, 2014 Author Share Posted May 13, 2014 The discharge temp using this comp housing is lower. Helps top end by a little. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7282035 Share on other sites More sharing options...
hypergear Posted May 13, 2014 Author Share Posted May 13, 2014 And any one into Nissan patrol 4.2L Diesels ? High flowed stock turbo made 121awkws on 15psi maxing out stock fuel pump. Stock turbocharger maxed at 81awkws. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7282164 Share on other sites More sharing options...
hypergear Posted May 14, 2014 Author Share Posted May 14, 2014 Video footages for the ATR28SS2 on SR20det from earlier Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7282760 Share on other sites More sharing options...
GTScotT Posted May 14, 2014 Share Posted May 14, 2014 My SLSS2 turned up today Looks good sitting next to my old highflow paperweight ImageUploadedBySAU Community1399964974.687270.jpg WTF happened to that compressor wheel? What highflow was that? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7282773 Share on other sites More sharing options...
KerrodR33 Posted May 14, 2014 Share Posted May 14, 2014 WTF happened to that compressor wheel? What highflow was that? It is a Kinugawa highflow. The oil feed line let go while coming onto the highway in second at high revs. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7282899 Share on other sites More sharing options...
KerrodR33 Posted May 14, 2014 Share Posted May 14, 2014 Getting there Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7283076 Share on other sites More sharing options...
Manuel Kasko Posted May 14, 2014 Share Posted May 14, 2014 It looks right at home 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7283085 Share on other sites More sharing options...
zebra Posted May 14, 2014 Share Posted May 14, 2014 Hoookay Some initial feedback on the TD06SL220.5G My car is hardly sorted atm but is as follows Dead Standard 1JZ-GTE and Auto ETM 6 into 1 merge collector manifold Hypergear 50mm External gate 3" dump pipe into a 2 1/4" mid pipe into a 2 1/4" twin system (yuck!) factory ECU So initial drive Builds boost at around the same RPM as the standard turbos...but feels like it needs a little more throttle to do so Once it sees around 0.2bar and 3000ish rpm it comes on like a light switch even at under half throttle (no WOT runs re: standard ECU) running the 0.8Bar gate pressure This combo is going to have a monster mid range once I finish the new exhaust (3.5" with a Hooker super comp aero chamber muffler) and fit the ECU and fuel system but I feel it is not going to be linear, feels like it will always be a light switch turbo, but comes on early enough to not be a huge worry, however I will report back once its tuned and I drive it in the wet. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7283134 Share on other sites More sharing options...
iruvyouskyrine Posted May 14, 2014 Share Posted May 14, 2014 Getting there ImageUploadedBySAU Community1400060537.368503.jpg Hey Kerrod, what exhaust manifold are you running with this setup? thanks Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/491/#findComment-7283187 Share on other sites More sharing options...
