TR43 G2 is running a .63 rear which is what the OP6 Rears are. But with a Vband rear. If you have a OP6 rear already then we can just high flow that. Less headaces when putting every thing back. Response wise I would say its touch bit laggier then before high flow.
  hypergear said:
TR43 G2 is running a .58 rear which is what the OP6 Rears are. But with a Vband rear. If you have a OP6 rear already then we can just high flow that. Less headaces when putting every thing back. Response wise I would say its touch bit laggier then before high flow.
TR43 G1 trims seem to be making around 240rwkw on 20ish psi on RB20's
so i'm assuming that since a G2 is meant to be 30hp larger your should see around 255-260rwkw on similar boost?
how would this compare with the gt2076r 0.63 internal gate custom tubro you posted a few pages ago?!?
ok now, so now that is stated.
my theory is IF you are chasing 250 RWKW in a R34 with a OP6 housing the best choice is to HIGHFLOW it.
IF you do NOT have a OP6 your better off going a TR43G2.
when i googled Hypergear i cam across a supra forum and i believe you were making a TR43G3. If so will that bring around 270Rwkw?
regards
Chris
TR43G3 is later on called a TR43i. Yes we've maxed that on a CA at 300rwkws with 24psi of boost. For standard build RB25det engine with 19psi of boost internal gate. it should get some where around 250~270rwkws.
We also managed to high flow GT15 turbo off a single soarer with ATR28G3 spec. The GT15's got lot bigger turbine housings. So in case you got a Soarer with a blown turbo we can also make it work.
interesting as we do a lot of jzx100's here. Got 2 in car park now :dry:
so what turbo would you suggest to run on a stock rb20 trying to make 260rwkw on 20-24psi of boost?!?
has to be low mount to bolt onto the stock manifold and internal gate with the best response possible...
im thinking the TR43G2 but maybe its not big enough and should go a TR43G3 (aka TR43i???)
Edited by Cerbera
Guy on here used to have one he said 18psi at 3800 (that what he set his PSI too) so for something that could make 300kw thats pritty good, and that was with no cams just injectors afm and ecu and a light tune was 245kw.
So with cams better ecu and right tune sould see some good power.
Oh and it was a GTS-4 so RWD should read higher power.
Edited by raZ1911
Hoo yea. thats that Black R32 guy. Its abit of sad funny as I rang him for a copy of dyno sheet and he was asking me if any one found his car any where.
So is 250-270rwkw your highest rated hi flow for an rb25, i currently have a hi flow with a vg30 rear and core with an rb25 hi flowed front and bigger wheel (specs are HERE ) and i have a blown standard turbo, what are the chances of making something that will get around 300rwkw with an auto?
Assume you have a strong enough Auto box, you need some thing at least in .63 rear housing to do that. We can make a .63 Vband reared ATR28G4 which will get you about 300rwkws at 20~24PSI depends on mods. The OP6 Rears won't do it. But the VL's RB30 .63 rear housing can do it.
What what the price be on one of those and will the oil and water lines be a direct bolt on or will they have to be custom as well?
The price is $1060 including 14psi internal wastegate and Braided oil feeding line. Your Stock water lines fits. The rear end of the turbo is a 2.75 inch Vband, We supply the O ring for dump pipe making, and most of your local exhaust shops can make the dump made for roughly $200.
Would the hks adjustable wastegate i already have fit?
  hypergear said:
If its made to suit a T3 turbo It should. It depends on how long your actuator's extender is.
I have it on the hi flow thats on my car atm, dont know how long the rod is ive never screwed it all the way out.
    • Good tips, will get on those tomorrow. When doing the maintenance I did move a few of those connectors around, and things that are old tend to not like moving around. (Like me).
    • Don't try it. It will be shit. Better chance of damaging the engine than gaining any knowledge about the old one. Maybe, but unlikely, especially if the O2 sensor is working. You can use NissDataScan to look at the stock ECU.   Cleaning the AFM is seldom necessary and seldom helps. The R35 coil & loom conversion should eliminate dud coils or plugs. But as you still have misses - look to the plug where the coil loom connects to the engine loom, and the CAS plug. Need quality connections there. Also look to injector plugs. And the AFM plug while you're at it. Also look to whether your injectors are clean and flowing evenly. Get them out and onto a testbench.
    • Good to know, I feel like I am in for a rollercoaster ride that looks like a sine wave.
    • You'll fit right in. Acceptance is the first step.
    • Hey folks. I've been lurking and browsing the forum for a while, since I got into my head that I wanted a skyline. Having purchased an overpriced completely stock GTT, (only "mods" it has is HKS pod filter and catback) now that it became legal in the US, it was all glorious and sututu noises here and there. But then I wanted to do things right and went to do basic maintenance. After all the fluids, filters done, I did the spark plugs, that's when the problems started.. First the car started spluttering at around 4.5k RPM. Which I gapped down the new plugs and that solved the sputter there, but the car now always misfires at idle with pops when lifting off and shifting 2nd to 3rd. Similar to the issues in this recent thread. I've been banging my head against the wall, reading the threads here and trying suggestions for a couple months now, so decided to start this one to explain exactly what I tried and what is going on. The symptoms of the issue: Idle and low revs misfiring intermittently. You can hear the exhaust tone change and the shakes on the shifter knob. It happens frequently, but doesn't seem to have a rhythm to it. Pops when backing off throttle. It pops and or burbles almost feels like it spits fire when it pops. (Happens mostly in 3rd gear at around 2k RPM). When under load and after 6k RPM, it also pops when shifting from 2nd to 3rd. There's a ticking noise at around 2k RPM in 2nd gear going downhill, seems unrelated though but I am out of educated and downright dumb guesses. Not noticeable lack of power when putting the car into load. The attempted diagnosis and solutions: Unplugging coils when the car is running This did nothing to change the idling and tone shift for every cylinder. Checking the exhaust headers with thermometer They all are within what I'd say it is margin of error of the laser thermometer New spark plugs Tossed two new sets, copper, iridium and using the old ones, still misfiring, even re gapped to 0.8mm, still same thing. MAF cleaned with the "specific" spray cleaner No changes in the issues what so ever. Brand new loom and r35 coil conversion (was going to add the r35 coils anyway) car runs arguably better, still misfires, but seems like does less frequently. Placebo? Code 21 now being thrown, thanks nissan gods. Removed the CAS to check the shaft for play or anything. CAS seems all fine, nothing that indicates any issue, visually speaking. Things to attempted next: Ordered a new MAF (chinesium from Amazon, to be able to return regardless of result). Fuel with proper gas, maybe it is this California water that they sell as gas that is to blame? Plugin the link ECU and check the info using the built in base map. Go back to BMW and eat my rob bearing breakfast without milky oil mixture.   Do any of you have experienced anything like this or have any suggestion?
