Stao, what's the main difference between the G1 - 4? If I have the G2 0.82 and am making 285rwkw on 15psi, I would expect similar on 17psi as above. Not that it's a bad thing at all :laugh: just curious as to my results compared to the above.
I guess G1-G4 's all got different wheel profiles and rated differently in HP, Lower HP rated turbo will produce better response. How ever most of our turbos are engineered specifically to what a customer's asking for, so its not really following the guided specs.
The twicked ATR43G3 is running a 58T 76mm which was custom made, it seems to flow lot more air down low in a .70 comp housing. It is interesting because larger comp housings has shown greater lagness in my previous testings but it seems to make the turbo more responsive with RB25s.
I believe mine had a 58T 76mm from memory, but with only a 0.5 front cover... May be interesting if I end up going a RB25NEO to see results with either my 0.63 or upgrade to a 0.84
Need a .82 rear for the RB25det Neo engines. You will find the .63 is restrictive up on the top.
Little more updates. This is the result from Harey. from PU high flow with a R34 GTST. Its got abit of exhust and intake restrictions. Final run of 280rwkws @ 17psi 98 fuel.
Sheet:
As some of yous already seen from the public thread, This is our updated 21U R33 GTST factory turbo high flow profile.
I did read many posts in regarding to high flowing with the factory 21U RB25det R33 turbine housings. I did some testing in it with a modified exhaust wheel, I like to share this information publicly and I believe this is the absolute max this thing can flow.
I also managed to hold 20psi flat with that small housing using a wastegate controller and a high pressure actuator on 98 fuel.
The max power it managed was a stunning 297rwkws when its cold, with final run of 273rwkws consistent. The little sucker was burning red hot.
Sheet:
Video footage for all 3x runs are recorded:
I'm little bit concert with high back pressure. So this profile will not yet be commercially available after further testing and examination for component wear.
Why is the boost dropping off in the PU hiflow its 0.82 isnt it?
That would be from intake and exhaust restrictions and injector seal leakage. Also Trent didn't had too much time adjusting wastegate controller that night. Its getting back on the dyno tomorrow.
Yeah I am still sorting some things out. As Tao said lots more to try. We also just discovered the front injector is causing a boost leak so that will need to get fixed before any more testing. I will have more results next thursday.
We have a few more wastegate settings to try as well as dropping the exhaust as its suspected to be a bit restrictive.
That 279rwkw is actually at only 15.8psi so plenty left in it.
Its a bit different to Tao's demo car cause all these things are sorted and you get a direct comparison.
Fair enough look forward to the results.
Further updates:
This is the very first prototype of our Duel Ceramic Ball bearing turbo CHRA. Its running two air craft caged ceramic ball bearing cartridges in a fully CNC machined billet aluminum bearing casing. Its been then inserted into a GT28 bearing housing for water cooling ability. This turbo is oil and water cooled.
Short Video, span by a small compressor.
Above CHRA is made to suit a OP6 Rear housing for 500HP high flowing applications. Since OP6 housings are running short I will be testing it in a .63 ATR43 rear housing with a .70 Comp housing. Hopefully it works according to plan.
Big thanks for a anonymous member who've donated a OP6 rear housing for this project. We will be running it in a real OP6 rear. Looking forward to consistent 300rwkws.
If they test to work 100% you'll be looking to spending about $1900 to build in any of the brand new ATR43 units or around $1600 with Kai high flows.
Also The high flow page has been updated. 2x New high flow profiles has been added.
Standard high flow options using standard housings:
21U R33 turbo: 240rwkws
OP6 R34 Turbo: 260rwkws
Kai High flow using standard housings:
21U R33 turbo: 270rwkws
OP6 R34 turbo: 290rwkws
PU high flow using .82 rear housing:
21U / OP6 turbo: 300rwkws
Detailed information is at our website:
http://www.digi-hardware.com/rb25t3hiflow.html
maybe these are becoming a little bit more expensive because they are bolt on items ( i think ) ? but u are correct u can buy garrett items for far less but these are not bolt on i guess :(
looks good stao,but wow the prices r gettin really high 4 a custom built turbo? :)
GCG charge about the same for a bb highflow, I wouldnt say it is high for what you are getting.
Can pay less for a genuine Garrett turbo
I really doubt this.
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
