Also if I run external gate and plumb it back, then wouldn't this be considered as road legal "internal" gate?
How effective is an external gate plumbed up to the internal gate location?
It wouldn't be legal as it would be seen as a form of boost control modification.
I'll be interested to test it only if its rated road legal. I received a $760 fin from EPA (01/01/09 first day of 09 lol) in Vic for having an externally bleeded gate. I will be more interested in developing a street legal sort of setup.
I'll be considering to do those sort of setups if plumb back is legal.
and plumb screamer back in to the front pipe.
Where did i say 1000rpm better response? I didn't.
I said quite clearly - power band. Useable RPM range.
All your dyno sheets tend to end @ 7,000rpm.
Most results you've shown tend to show a drop that usually starts around 6500rpm - a power band of 2500rpm (4000-6500).
If the sheet goes to 7500 (i think i saw one?), the drop was quite big (30-40rwkw IIRC).
To date you've not really answered when questioned about it in 2-3 threads now, and I'm not the only one that keeps asking.
I've not seen a 3071/3076 drop off that harsh ever.
i have to agree, my old high flow which is the same one that held 20psi all the way to 7200 also did not drop off, just flattened out at 6500 and held the same power to 7200.
And Stao, blaming every dyno curve that drops off on wheel spin is getting a little old.
Strap the car down better, but if its not wheel spinning at peak torque i doubt it will wheel spin once the torque drops off at high rpm.
2 things, your first comment is void - nobody plumbs it back to the factory gate position. The idea is they plumb it into the front pipe later down the exhaust.
2nd point, it is legal from an emissions perspective however ANY modification in just about ANY state is considered illegal.
You highflow, is as illegal as it gets.
it isn't blatantly obvious to anyone who sticks their head into the engine bay though...
One other thing popped into mind, wouldn't say a Garrett core inside stock housings make the compressor flow all kinds of f**ked up?
Yep, hence the 1500rpm power band and massive drop off after 5500rpm
Its due to the massive wheels inside small housings, same goes with the ct12 highflows that many companies do, all that achieves is a shit load of lag and maybe a 15rwkw gain overall for the soarer guys, because the housings just cannot flow enough air, so you stick a shit load of boost through them and all it does is superheat the intake air.
But on the same time I don't think your high flow made that much power either. Keep in mind this is 305rwkws final result. It doesn't seems to affect power under 260rwkws. Can you scan a copy of your sheet?
Plus I've never blamed wheel spin for drop off. Its blamed for incorrect RPM reading. So at moment I'm doing all my runs on a hub dyno.
I think I can get away from the drop with internal gate on high powered applications. Stay tuned.
It will wheel-spin at peak power not peak torque, sure the torque drops off but the overall power keeps climbing due tot he increase in rpm.
Edited by Rolls
Not in my experience, torque is what turns the axles/accelerates the car, hp/kw is just torque x rpm
Eg, I have driven quite a few big power NA big block bent eights, on the road they all broke into wheel spin at around the peak torque rpm, but hold at high rpm in the same gear and plant it they dont.
Just looking back to this high flow:
The final tune peeked 305rwkws at 6500RPMs and droped 15kws at 7000RPMs which still made it 290rwkws at rev limiter. I think its good enough as far as high flow goes thou.
But I consult with Tuners and engineers to see if this can be straightened by modifying few things.
Also when wheel spins. you lose peak power, torque and get incorrect reading. Note 2x power curves of the ATR43G3-P1 test runs. with and without people in the boot. That shown lots wheel spinning, and less wheel spinning.
This is my experience as well with various different high powered cars.
So that one holds to 7000rpm, but power comes on like a switch, it doubles its power in the space of 200-300rpm.
If you can fatten up the mid range and bring it on boost smoother it would be a winner.
Not it isn't, power is. Even though there is less torque there is more work being done (more power) so even though the actual force per cylinder explosion is lower there are more explosions going on. If that were the case everyone would make their cars massively under-square with huge strokes and tiny bores, sure it makes loads more torque but it makes less power and is hence slower.
That is all due to the rate that power increases, eg turbo cars break into wheel spin when the turbo kicks in due to the massive slope in power, it has nothing to do with the amount of torque though. Basically the wheels break traction then they increase in rpm, that increase brings about more power and makes them spin even more, where as at the higher rpm the power level is flat or decreasing, this means when they break traction the revs increase and hence it is making less power, this means the power drops below what is required to spin the wheels and it hooks up again. Nothing to do with torque level and everything to do with the slope of the power curve.
Really good article here on why this is the case.
http://autospeed.com.au/cms/title_Power-ve...48/article.html
Edited by Rolls
Maybe its just a coincidence that the greatest slope in power is normally around the peak torque.
Stao I wouldn't give a piss about those haters. There is noting wrong for putting effort on building cheaper and more convenient setups.
One thing I must point out thou. Have a look at your others sheets. It looks like this sharp tip off is only with your car. Heat from or boost drop formed power drop would round off a lot more smoother "blow" while your is just a sharp Tip. Looks like a rev limiter kicked in early or a miss fire. Get Status to checked it out before you tune.
Note there is no drop off at Harey's reading, whom is running your old turbo.
Edited by kwickr33
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
