hahahaha my suggestion was in no way serious :) I'd hate to think what kind of distorted readings the AFM would get when placed directly in front of the turbo inlet anyway.
So does anyone make an alloy one with bov/breather return that isn't $300 ?
Does anyone make an alloy one with bov/breather return that is good? I didnt know there were any at all, at any cost.
I just made one up myself... Just get a 3" 90 deg bend and weld on a few plugs then use radiator hose to connect between original return pipe and the custom intake
Thats exactly what i did. $10 scrap exhaust bend from an exahust shop. cut the bov return and oil breather metal return pipes off (about 30mm cut off) turned them around and welded them onto the exhaust bend, then 2 small hoses (about 80mm) long to join up the now cut bov return and oil breather.
Chasers made mine because, as other people have found, the rev210 mod does have it's limits. 2 x 45 degree bends were used in the end i think, they wanted it as straight as possible.
They did say it was tricky to get it to work, which must be what all of you guys are talking about.
I have the standard airbox and standard BOV, plum-backed.
Wasn't cheap, $300+, but still let me run everything as it was and in it's most standard configuration, whilst being the straightest possible pipe.
that should all be past tense, as i no longer have the car :)
Thats the next level of complexity again as you have to connect it up to the standard airbox. I am just talking about a pod filter so it doesnt have to be as precise.
I made THIS for the same reasons as above.
All you need is some alloy pipes and a welder.
I made this one 2.5" on the turbo end and 3" on the AFM end so no need for silicone reducers (ugly)
Good to see another way of doing it!
However, for the guys with larger turbos I am sure it would be beneficial to go straight to 3" as quickly as possible from the turbo. I know its the not exactly the same but its sort of like a bellmouth if it goes straight to the largest diameter. Thats my theory anyway.
Had car retuned today after I had a few issues fixed up...I'll be providing Stao with the dyno sheet to post up first once I pick the car up, but all I can say is that I'm very happy with the figure. Considering I asked the tuner to be as conservative as he could and very safe up top, it still made stupid power. He was skeptical of the turbo since he'd never heard of them before, but was pleasantly surprised (or astounded moreso) with the power it made.
Since it was running without any boost control, boost came up to ~17psi initially and bled down to ~15.9psi. Tuner took out as much timing up top as he could before it would begin having a negative affect, and it finished up with 11.5AFR. Not sure of the rpm yet, but at 15.9psi it made 294rwkw.
Safe to say I'm stoked with this result.
Thats awesome, can't wait to see the dyno graph.
Mine's going back on the dyno on monday too! last tank of fuel before i switch to E85 :D
You're a prick. I want some ethanol action :no:
Who's tuning it for Ethanol?
Sounds good! Keen to see your boost graph so don't forget to get a print out while you are there :no:
Also try and get the runs printed in rpm if you can
Not sure mate. I'll go back to Ed on monday to get a "before" and base tune.
Then I'll tune the AFR's myself and up the timing a bit. Then bepending on how Ed goes with the before tune i might go back to him.
Otherwise i dunno
As some already seen the ceramic ball bearing high flow results. This is based on a stock Rb25det with factory head, cams and cam gears with forged bottom. Turbo did have some unexpected boost creep issues due to a newer designed waste gating system.
Tuning video footage of 4x consecutive runs. with consistent 321rwkws:
Turbo has been pulled apart, we are analyzing its bearing components and modifying its turbine wheel refer to some skeptics for faster torque gain.
Also we will be testing some cage less air craft ceramic bearings for even faster spool time.
Also for people whom's interested in sleeving stock rubber pipe with metal and hopping for great HP. Below is a dyno comparison to show you it doesn't work. and please don't waste time trying. (The drop at 6500RPMs was from operator back off per discussion earlier)
I would highly recommend going fora 4inch metal intake pipe with pod. All ATR43G3/4 units will be now built with a .70 comp housing with a 4inch inlet unless special request.
Since I got no idea if Stao is gonna chuck these up or not, here's the dyno charts from my tune this arvo. I don't get a torque chart tho :ermm:
One shows power+boost, one shows power+AFR. They've been overlayed onto the graph from my first tune when I was having boost issues. The RED line is from today (though I dare say that will be obvious lol)
Big thanks again to Stao and his great work, another happy customer here :)
Thanks for uploading. I was about to re-size them first. Unfortunately above turbo had some shipping damaged to the actuator lever which caused it not been able to shut in the earlier run. Great to see thing's back in working order. Hopping to see more power at 20psi :ermm:
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
