12 hours ago, 4bidn1 said:
I should really put my glasses on before typing on my phone ?.
Thats not even English
I'm a full ching chong bing bong and my engrisher is better LOL
We sponsored topstages S14 for wtac this year, its an built sr20det with solid head and pro cams. Upgraded to our ATR43SAT turbocharger from Garrett GT3071. Car made more power through out the whole rev range and maxed at 381rwkws e85 fuel.
14500401_1188416121202317_74590799406876
Red: Atr43sat
Green: Gt3071
Philip island test run:
  • Like 1
Haha, the car had upgraded fuel pump later on so I upsized the turbo to an ATR45SAT which made 408rwkws on an aggressive tune. Backed to 399rwkws for tracks. It run 1.251 at Winston last week beating previous wtac winners result of 1.26
14542310_1188415847869011_41923078897209
14519735_1805987033011106_22834492266191
  • Like 3
I think 420rwkws is about the most this turbo can do. have to upsize wheels for more power. But Its plenty for what this car needs so far.
  • 3 weeks later...
Hi all.
I'm about to order the atr43sat for a 25. Looking to make 450-500rwhp Questions are:
Can that be had internally gated through standard dump?
If I need to change dump etc might as well go ex-gate yeah?
On 2016/5/16 at 0:42 PM, CEF33Y said:
Speaking of Non VCT, low cr engines, did you ever end up doing any development with an RB20 Tao?
There are so few of them around and took a while to find the right car. Picked up a 93 model R32 GTS4 in good mechanical order. Will be starting developments based on R32 Rb20det engines. My goal is to 270rwkws on pump 98 fuel with good turbo response.
Car is pretty basic with a return flow cooler, and a turbo back exhaust fitted. I will be Nistune it and drop in some ID injectors for starters. I will list prices and places as project move along.
  • Like 2
haha true, my plain is to drop in a RB25det NEO motor off a Stagea in it later on, Nissan should've done that years ago.
I will be using our ATR43SS1 as well as doing some high flows, and see if there are room for improvements.
  • Like 2
Will be moving to a new ATR45SAT Ball Bearing soon.
Will put results up here once dynoed.
Below is what im going from -> to.
ATR43SS2+ gate off housing - > ATR45SAT BB
Stock ExhaustMani - > D2 Stable High Mount + Gate of mani
44mm Tial Gate - > 50mm Turbosmart Gate
Stock Plenum - > Custom FFP + Sard Fuel Reg
Single 460 Walbro - > Probably Surge tank
Nistune ECU - > Adaptronic ECU +Wideband/Airtemp sensor
Z32 AFM - > MAP inside adaptronic
E85 - > Still E85
Stock Head - > Only doing ARP headbolts
And a bunch of other random stuff
Was ~450 hp at the rears - > Hoping for + 550 hp at the rears
Current full boost is around 3800 @ 20-21 psi
Im hoping for similar response, looks like it will be close.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
