1 hour ago, hypergear said:
Intercooler wise I will be voting for PWR 600x300x89mm and run that with Plazmaman's cooler piping kit.
I can't fine those dimensions listed anywhere on their site.
100% sure it's x89?
Hi Tao , I will contact PWR today about their 600 x 300 x 89mm intercooler .
I went back looking for your posts and noted some dated 18.8.2016 (P 587) where you bought another R34 GTt and tried the typical Blitz return flow and a flawed Japanese exhaust . You were trying to prove to a customer that his setup was the issue not your turbocharger .
I think I'm ok exhaust wise and that 0.82 GT3076R is a reasonable thing but that Blitz return flow has to go and I just want to hear you say that your 3-400 RWKW results have been with PWRs intercoolers and generally Plasmaman pipes . I realize the higher numbers usually come from using E85 fuel . Don't suppose you have pics of these PWR Intercoolers ? Would you consider stocking them .
Also what do you recommend for an R33 as cold air intake . I have Scottys intake pipe plumbed into a Z32 AFM and the std air box and snorkel .
When everything else is "right" I'll look at turbos again .
Thanks in advance cheers Adrian .
Just off the phone to PWR , they don't know of any 600 x 300 x 89mm intercooler . They do an R33 GTR one Pn PWR 154641 600 x 265 x 81 rated at 1000 Hp . Has swept back 80mm in/out .
Tao is this the one you mean or do you have a different part number .
Cheers A .
Edited by discopotato03
  • Like 1
I advise everyone to obtain that cooler direct from PWR. I trailed it is because majority people whom complaint about a boost tapering issue had a blitz return flow cooler and so did mine. Yes I changed nothing but intercooler kits during those evaluations and PWR 600x300x89mm cooler has proven to be the best one out of the bunch. Once again my advise and test data on this matter is general.
I think you missed the part where he said that PWR said over the phone that there is no cooler of that measurements 600x300x89mm
The closest they have is R33 GTR PWR 600 x 265 x 81
So there must be confusion with either your measurements or the one you have isn't PWR?
Can you list the part number for your 600x300x89mm if you have one?
18 minutes ago, hypergear said:
Part no. is PWI5813 exact measurement in my invoice is 600x300x81.
Awesome, thanks (Y)
Looks like that one has 3" outlets as well, are you cooler pipes all 3" or do you run a reducer?
Alright have the diagrams from PWR so for those that want to know everything .
Core 600 x 81 mm
Tanks 93 width x 70 horizontal length , barbs 76.2 (3") 80mm center above base height .
Threaded mounts on 500mm centers top and bottom .
This is interesting in that it uses the same sized core as the 33GTR one but a little longer . The tanks are generic and the mountings much simpler than the model specific 33 GTR one . Think I'll go with one of these , thanks Tao .
I'm curious as well how people are running their cooler pipes on the R34's
My previous R33 had the hold under the battery tray, went over the pits here in Canberra and they didn't look twice at it. However I hear that NSW has more of a problem with it.
@hyper-gear have you done a PWR cooler with return flow piping or similar?
Maybe I could swap out the core and keep the same piping if that's not a restriction with the 90 degree bend.
Im pretty sure the return flow piping is the main restriction, especially with that 180degree bend. Swapping the blitz core for the pwr core but retaining the piping probably wouldnt do much.
On 8/18/2016 at 11:48 PM, hypergear said:
This is an perfect example of how important it is picking the right supporting and differences it makes to overall performance.
@vxsr33 This person managed 400rwkw using what looks like return flow cooling and custom CAI.
I love the look of this setup.
Obviously not a blitz though, I think it was PWR
  • Like 1
Yeah thats the thing that gets me, seems there is always a few cases of people getting great power with return flow coolers.
I assume that you can still make good power with a return flow, however unroadworthy piping just flows better and helps make power more easily.
That setup looks very stealth. I like it
There's no reason why a return flow cooler couldn't have a decent end tank and pipe connection that flows properly.  None.  It may be the case that most (or maybe just many) of the common ones suck and there's a small number that behave themselves.
  • Like 1
I saw one that I think Scotty posted, pipes running under and up where your radiator hoses are, means it will have to be custom pipework but that's not too expensive. Especially if it eliminates the costs of cutting a hole under the battery tray.
I think later down the track I'll just buy a PWR intercooler and some custom pipework to run nice and short without cutting.
You're right I messaged Trent about this on Facebook and he said it is definitely a normal cooler with custom return flow style piping for the stock appearance. Scotty also mentioned that it's possible to make a normal cooler work with standard pipes (no cutting) but it's custom and needs to route around the radiator.
The other issue that Trent mentioned about this Stagea was that there was 5psi+ of back pressure and by simply removing the cat it picked up better response and more power. This is why Tao says if you're having power issues to drop the cat and that will tell you if its an issue also.
Hope this helps get you in the right direction.
  • Like 3
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
