This is my return flow setup:
10929096_1009459115735114_79092875403676
In saying that i will be going to a custom piping setup in the next month. Just to make it cleaner less pipes and to fit a 4inch pod
  • Like 2
Mmmm that looks awesome! Have you got any more pics?
Only pics i got:
1939497_1009458549068504_274021022972297
10559751_1021991617815197_81149067125310
If anyone is interested i might sell my existing cooler pipe setup if i dont need it after my custom one
39 minutes ago, Manuel Kasko said:
@blah_blah Tony, those look like 3inch cooler pipes yeah?
Pretty sure the U bend and connecting long pipe is. the rest of the piping is either 2.5 to 3 inches
Would need to check to be sure though
My R32 has the same cooler kit, It was abnormally laggy, and I tried doing:
might be worth while give it a short and see if there is much differences in throttle response. Mine was huge.
Well I'd expect a huge difference in throttle response with no intercooler too!
So a water to air cooler, aka celica gt4 style which keeps the inlet tract super short might have some benefit for rb20 tragics? haha.
How is the research with the RB20 going?
haha the RB20det is probably the most troublesome, in past cases I just need to bolt up the bits, sort out the ecu and its good. But in this case I had to diagnose and fix heaps of worn OEM pieces that I didn't expect, plus mods fitted by previous owners didn't work as they seems. Still fixing and setting up test bed at current stage.
  • Like 1
The return flow setup shown on top of the page,is the same setup
Vl turbos where running in the 90s and still some today.Core depending ..cant be to bad for flow as they run 9s on 30ish psi with autos and 3582s
Cant be to much pressure drop slowing them down..
Cheers
Darren
On 15/01/2017 at 10:37 PM, V28VX37 said:
I've had this small issue recently with my ATR43-SS2 (2013) where I occasionally find a drop of oil underneath the front housing. I have checked the water and oil lines and they are all fine and tight. I've also been conscious to wipe the housing clean each time in an effort to pinpoint where it's coming from.
I took the photo below just then, you can see a bit of oil collecting at the edge of the housing and right under one of the housing bolts. It also looks a little wet right around the bolt so I'm wondering if that's the cause? I chucked a 13mm socket in there and tightened it a touch (it turned easy enough) but didn't want to overdo it as I don't know the torque specs.
@hypergear Tao have you seen these turbos spring a leak there before? What's the torque specs on the housing bolts? Cheers
Bill and I were wracking our brains at Sandown about this and we reckon it's actually the oil feed line on the top of the core, leaking under the fitting that connects the braided line to the core. That sprays oil onto the rear of the front housing, which then drips down to the comp cover as above. The fitting under the oil line in the top left corner below:
Apparently there's a copper washer under that fitting and it's important that it's annealed before installation (?).
Tao, any pointers on where I could get a replacement fitting and copper washer for this turbo (ATR43SS2 late 2013)?
Cheers
Cheers
I don't think the fitting would require replacement, just the copper washer.  Autobarn should carry them, if not try a pirtek or similar. Annealing definitely helps as it allows the washer to be crushed nicely and provide a good seal imo.
  • Like 1
Cheers
Yeah I have also noticed that every few events it would start leaking and the washer needs to be replaced, at first I had a alloy fitting and the fitting also needed to be replaced as it must of been deformed from the heat now using a steel fitting seems only the washers die.
  • Like 1
its just a 12mm copper washer you can get them form Auto spare shops normally hanging on a wall pack. the drain adaptor gasket is to suit OEM drain pipe, cheapest place to get that is Ebay or simply cut one out of gasket paper. No silicon glue on either of the fittings.
  • Like 1
Thats a pretty reasonable figure consider for the boost given. how much power r u hopping for? More then happy to make it bigger free. :D
