9 hours ago, Super Drager said:
How tight of a fit is it? Doesn't foul on anything?
It's a pretty tight fit but not impossible - Only thing it does foul on is the aircon drain pipe which I just chopped shorter.
The only pain in the ass thing is the flange to manifold bolts are a bitch to get on and require some patience.
  • 1 month later...
Some video footage from Last weeks Victoria Time attack at Philip Island GrandPix.
ATR45SAT Turbocharger Powered Top Stage S14 SR20det (400rwkws @28psi, E85 fuel). Taking first in Modified class. Driven by John Richardson
  • Like 2
Posted in my own build thread, but relevant for this thread.
I got myself a Hypergear G3 high flow on a 21U turbo. I've had pretty good results, making 230rwkw @ 14psi on 98RON. This particular dyno graph shows boost dropping at the top end, this is because (due to my own request) Tao put on a 10psi OEM wastegate, and it just wasn't up to the task.
I've put on an aftermarket wastegate (pictured) and it now pulls 18psi happily all the way to redline.
I installed the turbo myself and it was very straightforward. Overall stoked with the results.
  • Like 2
Just repaired a blown Borgwarner EFR with no exhaust wheel. Luckily the compressor wheel is undamaged. It has been fitted onto one of our ATR CBB cores with a custom grind turbine wheel to suit the original turbine housing profile. Looking to match original power figure before turbo failure, hopefully with a bit more torque through mid range.
  • Like 1
Time for some e85 then
Post mortem review - what caused that failure?
First run with Brand new Ceramic ball bearing T4 print ATR44SS prototype hit the dyno this afternoon. Car made 406rwkws @ 22psi, Pump 98 fuel. full boost by 4000RPM. Stock 2JZGTE, sorry not an RB this time.
  • 3 months later...
Hello and greetings from Finland
I have had my skyline for 8 years now, and now its finally time to upgrade the turbo. I am looking for around 300rwkw with 98 fuel. With supporting mods of course. Since i have a limited budget i was thinkin of the ATR43G3SAT with thrust bearings. The price of that would be perfect, but i couldn`t find any dyno results or other info of that turbo with thrust bearings. I know that bb core is recomended with this, but i really like the price of the normal bearings and if it still would be good enough, it might be a choise. With bb core it seems to be really amazing. Or is there some other options i should consider? Maybe high flow or ss2? I am looking for the most cost effective way to get good end result.
For up to 300rwkws region a brand new ATR43G3SAT turbo is recommended.
ATR43G3SAT bush bearing, internally gated, P98 result based on a R33 Rb25det engine:
  • Like 1
Thanks for the dyno graph. It looks pretty good in bush bearings too, but there sure is noticeable difference between ball bearings and bush bearings. About 70 Nm and 20 Kw in 3500 Rpm, if i looked correctly. I have couple of weeks time to think which one to get, before i get some money. I will go with teh ball bearings if i can afford them. If i can`t i will go with bush bearings. Either way i go, i think i will have a good turbo.
Back to back on the dyno measuring 4th gear paddle to the metal, there isn't that much of a visual differences to the curves. Take everyday road driving with partial throttle acceleration the differences are very noticeable.
There has been quite a number of updates applied in terms of wheels, housings and bearings in recent years so we will be starting another R34 GTT modification project, it will used in the development of our SS Ceramic ball bearing series turbochargers.
Car is a 2000 model with 80,000KM on the clock, bought from an mature enthusiast whom spent quite few coins at it with:
 Split fire coil packs
700cc injectors (Bosch?)
PFC ECU + Z32 AFM
3 inches Xfroce Varax exhaust
Koyo radiator
High flowed OP6 turbo (appeared to be an old XTR model)
Walbro 255 fuel pump
NPC Heavy duty clutch
HKS return flow cooler kit.
Setup on the dyno for the first time, after few power pulls the turbo started to make some funny noises and we stopped it at 226rwkws at 11psi, Peeked 14psi at 4000RPM.
Other issue worth mentioning is VCT. Using factory ECU/many aftermarket plugins, VCT solenoid produces a very distinctive "click" activation sound on throttle opening. PFC activates it in gear, so you should hear it clutched in 1st and a tap on the throttle. Mine is not clicking, later diagnostics have revealed signal output problems from the ECU. If VCT is not activated, there will be a lose in boost response by roughly 500RPM, and I found VCT problems frequently occurring with customers using old PFC plugins.
 I have re-high flowed the OP6 turbocharger using one of our ATR43SS2 ceramic ball bearing cores:
Further dyno shown an improvement in response of 600RPM while a 27kws increase in power. 253rwkws @ 15psi
we had some boost taper issues on the dyno, and MAP comparison have once again shown a flow restriction caused by a return flow cooler. Boost pressure before cooler: 22psi, after: 15psi, pressure drop: 7PSI
The plan before my next dyno run is to trail PWR's vertical flow cooler as they do make one that bolt on to an R34 GTT and will be replacing the PFC with the latest Adaptronic Modular R34 plugin ECU.
  • Like 1
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
