Straight up convert to top feed, use 1/2 height injectors that are stainless. The Bosch 1150cc (at 4 bar) are unmodified. Just don't use the bottom collar. These injectors are commonly referred to as Seadoo Injectors. At 3bar they're 980cc.
Or get a set of Siemens DEKA V 80lb (~875cc) short stainless injectors and a normal top feed rail. All you need to do is trim the spacers to suit. Will fit snug underneath the stock plenum too and provide you years of endless joy.
My personal best was 320rwkws on E85 fuel. This car actually made more power. Looks like its got FFP, cooler and exhaust plus fuel and ecu. It might have cams as the power curve lookes like it has no active vct.
Are there any results for the ATR45SS on an RB? I'm tossing up between the ATR45 CBB and ATR45SS CBB. Tao what would be the expected difference in lag and power be between the two? Both external gate on a proper manifold on a 30DET.
Hi, Rb30det is different to Rb25det, its heaps more responsive. Both ATR45 and ATR45SS works fine depending on how much power u r chasing for. I've personally used an 700HP ATR45SAT in a 2JZGTE no VVTI, the end result would be very similar to a Rb30det.  Car made 406rwkws @ 20psi on P98 fuel, full boost by by 4000RPM.  So what sort of power r u chasing for and will the car be running on E85 or P98?
Hi Tao,
I should add I have an ATR45 CBB 0.82 on an RB30DET (different car and engine) and have been happy with it so I know what to expect from an ATR45, just curious what the difference would be with the billet compressor. Power goals are 450 give or take 20-30 so I know both turbos are in that ballpark. Will be flex tuned on E85 in a Stagea and keeping VCT.
For 450rwkws ATR45SS-1 with 63mm billet wheel will do. Next size can do 520rwkws+ on E85 they works extremely well with XR6 BA/FA, but would be considerably laggier working with a 3L.
  • Like 1
Based on that would it be fair to expect that the SS-1 would give 20-30kw more than a normal ATR45 at the expense of 2-300rpm response? I'm just trying to figure out how it would compare to my other 30DET.
The ATR45SS-1 I'm pretty happy with and I would run that on Rb25det with a smaller rear end. when tested on the 2JZ, The response is almost identical to the normal ATR45  that made 30kws more. This particular comp wheel works with a normal ATR45 turbine.
Great result to share from Garage 7 tuned Rb25det Neo powered S14 running using one of our TD06SL205 turbochargers. This is an custom built turbo based in a TD06 rear end, externally gated.
Car has: 1000cc Injectors, Link ECU G4+ Storm Flex Fuel and usual supporting mods.
Peek power made: 308rwkw on 98 and 378rwkw on E85.
Fabrications done by: Vulcan Performance and Fabrication
Dynoed and Tuned by: Garage 7
FFP modifications done by: NDR Fab Precision Race Fabrication
Car owned by: Matt G
Sorry if a bit OT .
I was under the impression that this was a fail on RB25 plenums - or at least R33 spec ones .
Tao I'd like to hear your opinion on this one as I took your advice and fitted your preferred intercooler with a Just Jap over the fan pipe kit . It would be good to use a bend and throttle mounted on the plenum if it can be made to work properly .
Thanks in advance , cheers Adrian .
Plenty have done it and plenty say it's fine.  Many of those engines may have died, and you wouldn't hear about it if the plenum distribution was to blame because then the person who claimed it was fine would have proven themselves wrong.
But....I must stress, I don't know that it's not fine.  I only have very strong suspicion that it's not, because those plenums are not set up to receive air for all 6 cylinders from the front end.  The internal shapes are set up to receive it from the side.  I'm enough of an aerodynamicist to be very leery of that.  And I have never seen anyone report on 6x EGT probe results showing that it is fine.  On that basis, I simply wouldn't do it.  I'd be less worried about the various large plenums that bolt onto the bottom half, because at least they are simply big arse volumes on top of the runners, with no odd internal shapes to interfere.
  • Like 1
Hi, the Car's running 22psi to produce results above.
With that FFP modifications,  one of my tuners did mention it feeds CYC 5 and 6 more air then the rest causing them to run lean. I don't have personal experiences with them, so I can't comment.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
