Most i seen was 266kw from my car 25psi dropping e85 and that was with the larger rear housing .86
Stock bottom end sr but
I would reccomend going the atr28ss2 in bb with .64 rear housing more responsive due to the smaller rear and i made 280kw with this
On a built motor with larger cams and custom exhaust manifold i would see it making 300kw
Action Dan: Yes. the factory exhaust manifold is a restriction and SR needs cams to make power. Plus your usual free flow FMIC, induction and exhaust.
Ask tao im sure he can arrange that
Most results ar from rbs but usually all in by 4000rpm and there only running t3 single scroll
Twinscroll will help alot hence why evos get away with 300kw turbos but are still responsive
This particular SR20det engine is something built by forcedmotor works 4 years ago. It run one of our ATR45SAT turbo compete and won WTAC Open class in 2016 and is still a current world record holder of the fastest SR on Wakefield. Its on a single T3 scroll manifold running external gate, and that pumped 400rwkws on E85 fuel, 28psi by 4250RPM. Far as I know its just a standard rebuild, no VCT with forged pistons with 264  / 256 Tomei Pro cams. For around 350rwkws mark I will be recommending this turbocharger.
  • 3 weeks later...
Some results to share, This time is from Justin's drift car running with one of our ATR45SAT ceramic ball bearing turbocharger.
R33 GTST unopened engine.
HyperGear Atr45SAT Ceramic ball bearing turbo
6 boost manifold
Turbosmart 45mm Gate
Ebay 600x300x100 Cooler
ID 1000cc Injectors
460 lph Fuel Pump
3 inches turbo back exhaust
Haltech ECU
E85 fuel
Car made 397rwkws @ 21psi on a conservative tune for stock engine. Should see 420rwkws at full potential.
I would high flow the factory turbocharger using a ball bearing core with a G2 or a SS15 profiled wheel sets. the SS15 is a better choice for power and response.
For the best result use an Rb25det turbo. For a Ball bearing, billet wheel Ss15 profiled highflow looking at $1500 to complete including oil line.
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
