Most i seen was 266kw from my car 25psi dropping e85 and that was with the larger rear housing .86
Stock bottom end sr but
I would reccomend going the atr28ss2 in bb with .64 rear housing more responsive due to the smaller rear and i made 280kw with this
On a built motor with larger cams and custom exhaust manifold i would see it making 300kw
Action Dan: Yes. the factory exhaust manifold is a restriction and SR needs cams to make power. Plus your usual free flow FMIC, induction and exhaust.
Ask tao im sure he can arrange that
Most results ar from rbs but usually all in by 4000rpm and there only running t3 single scroll
Twinscroll will help alot hence why evos get away with 300kw turbos but are still responsive
This particular SR20det engine is something built by forcedmotor works 4 years ago. It run one of our ATR45SAT turbo compete and won WTAC Open class in 2016 and is still a current world record holder of the fastest SR on Wakefield. Its on a single T3 scroll manifold running external gate, and that pumped 400rwkws on E85 fuel, 28psi by 4250RPM. Far as I know its just a standard rebuild, no VCT with forged pistons with 264  / 256 Tomei Pro cams. For around 350rwkws mark I will be recommending this turbocharger.
  • 3 weeks later...
Some results to share, This time is from Justin's drift car running with one of our ATR45SAT ceramic ball bearing turbocharger.
R33 GTST unopened engine.
HyperGear Atr45SAT Ceramic ball bearing turbo
6 boost manifold
Turbosmart 45mm Gate
Ebay 600x300x100 Cooler
ID 1000cc Injectors
460 lph Fuel Pump
3 inches turbo back exhaust
Haltech ECU
E85 fuel
Car made 397rwkws @ 21psi on a conservative tune for stock engine. Should see 420rwkws at full potential.
I would high flow the factory turbocharger using a ball bearing core with a G2 or a SS15 profiled wheel sets. the SS15 is a better choice for power and response.
For the best result use an Rb25det turbo. For a Ball bearing, billet wheel Ss15 profiled highflow looking at $1500 to complete including oil line.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
