i'm guessing tin can or pipe the size of the intake pipe (to the turbo) with an air hose fitting and a bottle of soapy water (old school bicycle inner tube leak style) and go over all the joints
Have to ask Trent, he did some process to tune it. Dont know much more about it.
I just know the car feels a lot laggier and less power. Dont even really need a dyno but the dyno backs it up how it feels.
we were comparing different cars so the folder thats opened last will be shown.
Ahh k..yeah it was unlikely it would cause a 20kw difference anyway, just found it odd..
Could it be your WG isnt closing properly??
Stao, just a quick one I think would be valuable to your thread;
Are you able to back cut exhaust wheels?
I want to do this to make 2835 from 3071 or 3240 from 3540, thanks.
To trim or back cut wheels. yes we can do that. you need to give me the specs thou. or a set of 2835 housings.
Yup exactly, I bought some pvc caps from bunnings and use a silicone joiner and clamp to block off both the intake and the throttlebody. Then put an air hose fitting into the intake cap and insert air pressure. Any leaks I have had on previous cars have been quite loud and very easy to locate.
Just need to find my damn pump!
Interesting plot of the same turbo on Tao's car (yellow and green) and my car (red):
This is with the car running as it was previously making 279rwkw. Both yellow and red are running just off the actuator (no boost controller) but on Tao's car he is able to hold the boost flatter and get more boost up top.
Did you reinstall the bov afterwards? I cant see how a bov restrictor plate could reduce power? Affect driveability sure.
No i threw that plate in the bin it had cost me alot of money trying to find the problem! well it was messing around with the cars afrs, and at 10% throttle it would open the bov and hiss, could only hear it on the dyno and then the car would dump in petrol making it run really rich. I was there when my tuner did it, i couldnt believe it too but taking it out worked, u could hear the car was running so much better!
could it be possibly different parts such as exhaust, dump pipe, cat, air intake, intercooler brand, piping and design? better sealing of cylinders as tao has just rebuilt to stock spec with cp forgies. Maybe try another actuator? maybe a leak in a small pipe such as the ones going to the stock boost controller?
hopefully its just a leak somewhere which is nice an easy to fix :)
Edited by DJSimmo
Just to clear it up that red plot was when the car was running right. I am happy with my dyno being 5rwkw of so less for most of the curve and a bit less at the top cause the boost isnt holding. When you look at the peak power figure mine is quite a bit behind Tao's but if you look at the curve its only right up top that there is much of a difference.
I just want to get back to the red curve. Yup I am hoping its a leak somewhere too! I am not running any boost controller, not even the standard one. I am using the same actuator as what Tao used in those green and yellow plots. I will look into getting boost to hold flat later on, at the moment I am just focussed on finding this issue.
Ok, so got home last night and pulled out my boost leak tester. Found a big leak on the joiner on the outlet of the intercooler! It was quite late so I didnt get a chance to try and fix it. But I am very happy to have found it! Cant wait to get home to fix it.
nice... and you didnt need to pull the front bar :P
Don't assume that's the only leak though, still go over everything else to be sure. Otherwise, congrats! Hope it goes better now :P
Once I have replaced that hose and clamps I will retest for leaks until I am happy.
hahaha yup I was dreading taking off the front bar and driving across melbourne. I get enough cop attention already, without a front bar would be suicide!
LOL at that leak tester! Good work
Hahaha I know it looks ghetto, but it works really well. Because there is no other noise its really easy to hear the leak.
Exactly, may be a bit ghetto but cheap and gets the job done! Thumbs up :P
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
