Thanks mate, thats exactly the info im after.
It is a 25. i will go ahead with the original plan then but a g3 then
how does a G3 compare to SS2? im not sure what the name of the profile actually mean. as you said its a little confusing on the site.
ATR43SS2 is a brand new turbo that is capable of making more power.  Ball bearing option is highly recommended. It is also highly recommended  working  with our externally gated turbine housing kit.
Regarding to Rb20det highflows or builds from earlier discussion, they runs a smaller turbine and and compressor then a RB25det turbos. Can build it into a OP6 it would work similar to a HKS2530 with a modern wheel set for more power. Its not a bad choice.
Sharing another result. This is an ATR43SS2 on Pump 98 fuel making a pretty responsive 355rwkws @ 20psi.
R34 GTT Rb25det Neo standard engine
ARP head studs
HyperGear ATR43SS-2 ball bearing turbocharger
6 boost high mount exhaust manifold
50mm external gate
4 inches intake pipe
600x300x71mm front mount intercooler
3.5 inches turbo back exhaust
1000cc ID injectors
Haltec ECU
Tuned by Chequered tuning Melbourne
Final result of 355rwkws on pump 98 fuel / Ron 93 at 20psi, hitting 220rwkws @ 4000RPM.
Edited by hypergear
  • Like 1
  • 1 month later...
Sharing a pretty interesting result from a Rb20DET with Rb25det Neo Vct cams. Turbo's one of our ATR43-G2 BB model for RB20det in T3 .63 rear housing. Car managed to pull a pretty responsive 321rwkws on E85 fuel externally gated.
 Engine's in a Ford AU :D. Pretty interesting eposide to watch:
Updating result from latest model ATR43SS-3 Turbocharger:
Keepitreet R33 GTST 4 door
Rb25det Neo engine
Forged pistons and con-rod
Ross performance trigger kit
1650cc Bosch fuel injectors
Two 460L fuel pumps
Adaptronic plugin ECU
Upgraded Valve springs
Hypergear ATR43SS-3 Turbocharger
6 boost high mount TS exhaust manifold
Twin turbosmart 50mm external gates
Tuned at Chequeredtuning Victoria
Car made a final result of 482rwkws @ 24psi. Hitting 280rwkws @ 4000RPM with wide spread of power band and plenty of area under curve.
  • Like 1
  • 3 weeks later...
Updating this thread as some of yous would have seen on FB. Not about turbos this time, but a piece of information for people seeking the Rb2530det rout.
I've attached results of my built Rb25det with Kelford cams Vs my built Rb30det with HKS cams, making it a reasonable comparison of what Rb25det Vs Rb30det is like. Both engines had identical setups, E85 fuel, made the same power, while the Rb30det was 1300RPM better in response, more power every where and 137Mn of extra torque.
I’ve also attached result of differences HKS cams made in comparison to stock Rb25det cams on the Rb2530det engine.
  • Like 6
Thank you for posting here as well Tao! I'm not following social media so I very much appreciate it.
Though in some ways I'm not sure if it is good that you keep posting these promising results :D You are the voice of temptation.
Sharing a pretty good Pump 98 result:
R33 GTST forged rb25et engine
Standard head and cams
ARP head studs
Supertech valve springs kit
50mm external gate
1000cc ID injectors
Link ECU
Final result of 372rwkws at 25psi.
Update on my Rb2530det R33 GTST project, Now sitting at 497rwkws.
Engine Specs:
Rb25det head with forged Rb30det bottom
HKS step 1, 256/ 264 drop in cams
Fuel system:
Two 460L fuel pumps
ECU:
Haltech ECU
Turbo side:
Hypergear ATR43SS-3 ProR Turbocharger
Turbosmart 50mm external gates
Hub Dyno Tune: Chequeredtuning Victoria
Car made a responsive 497rwkws @ 25psi full boost by 3500RPM. Hitting 150rwkws @ 3000RPM and 340rwkws @ 4000RPM, with wide spread of power band and plenty of area under curve.
Edited by hypergear
  • 3 weeks later...
Updating result:
R33’s back at Chequered tuning for with another of my in-house built specials. Car had no other changes apart from the turbocharger, we managed to get:
516rwkws @ 26psi
569rwkws @ 29psi
606rwkws @ 30psi
642rwkws @ 34psi
Turbo’s holding boost with pretty consistent gain per additional PSI of pressure is added. Unfortunately my 3 bars Haltech Map sensor (vacuum is a bar) was very maxed, be back on the dyno to max out this turbo once new sensor arrives. Pretty successful day over all.
  • Like 1
  • 1 month later...
R33's back on the dyno again for development work, testing an new 6 blade 55mm prototype turbine. Using ATR43SS3ProR turbo for back to back test. New turbine shown a slightly laggier curve, but picked up 16kws on same boost pressure with smoother mid / top range power and torque band.
Final run of 509 rwkws @ 25psi
Engine Specs:
Fuel system:
Two 460L fuel pumps
ECU:
Haltech ECU
Turbo side:
  • Like 1
What RB wet dreams are made of, comes on super early and makes a great amount of power.
Would be an excellent powerband for a circuit car.
  • Like 1
Updating result, This is from our latest ATR45SS-3 model, Its made for 100bhp applications. Same car as above. It managed to pull 636rwkws at 34psi.  Drive ability wise, car hits 300rwkws by 4K and 450rwkws with 1014Mn of torque by 4250 RPM. Pretty good to drive with crazy amount of mid range torque.
Run against ATR43SS-3ProR turbo from earlier.
  • Like 3
hey guys
so i wana make 250-260kw atw on my rb25det, would the g2 be capable of making that power goal or do i need the g3? just kinda confused because on the site it says its capable of 350hp but doesn't say if its meant for an rb20 or if its suitable to make 350 on an rb25.
ill be running 550cc side feeds, a walbro 460, frontmount IC and all the other stuff necessary
cheers
21 hours ago, Desean Strickland said:
hey guys
cheers
Hi, G3 profile with Rb25det turbo housings will be fine for around 270rwkws on Pump 98 fuel internally gated. I can supply donor housings if interested. To make the power you will need 3 inches metal induction pipe, 600x300x100mm front mount cooler, at least 3 inches turbo back exhaust, programmable ecu, along with injectors, fuel pump, you've got.
  • Like 1
On 24/09/2023 at 12:06 PM, 33GTRV said:
Stao,
Just managed to get my hands on a GTI-R pulsar. I want a snappy 400 awhp, on stock stroke. Will do camshafts if required. What do you recommend?
Hi, on E85 fuel and internal gate, 54mm ATR28SS15 in T2 .64 rear housing will do nicely. I've used BC Step 2 (272dur /12mm) on SR20det for 300rwkws+ applications
  • Like 1
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
