I'm better on exhaust restriction. When my cat melted itself the other week, it drove around fine - just REALLY doughy particularly when trying to boost. Had a different note too, but you won't notice these things as you haven't experienced it "working"
Dyno without the cat/catback system connected would be my recommendation. It's very much likely your cat is farked.
Going to take my cat out today to see if it is melted or looks blocked in anyway, but not very keen on driving the car so will have to wait for my tuners dyno to be operational again. The rest of my exhaust is very high quality and very free flowing, so I can't see any restrictions there. Intake is 3" metal with no reduction in size or restrictive bends so again I can't see any issues there. I'm also suspicious of my cat so will have to wait and see.
Edited by Hanaldo
Greddy front mount, 600x300x100.
It is possible but the car drives fine, doesn't feel like it has any leaks and I can't hear anything.
I had a boost leak, it was impossible to hear or feel my boost leak. Even on the dyno with me poking my head around there is just too much other noise.
Only difference was more lag and the turbo was working its arse off to make the normal amount of boost and therefore the efficiency was down so the top end was down too. But nothing that would jump out and say boost leak.
Yours is very laggy for a 0.63 rear, so there is definitely some issue there. When I had an intake restriction it didnt change the lag, just the top of the graph was very flat similar to how yours is. I think yours has a combination of problems.
Have to remember this is a completely new setup and almost always requires some troubleshooting. The pain is that you have to get a tune for the large injectors so you really want to use the dyno time effectively.
Keep your head up and dont blame the turbo yet. Only thing worse would be to go out and spend 3k on a garrett turbo kit and then have the same issues.
Any chance you an share what methods you used to find the leak?
if it is the issue and it makes 50kw more itll be fine to give it a squirt in 1st gear once, bugger all load so you wont really experience any detonation etc, just give it enough of a squirt to see if it did make a difference, if so off to the tuners again.
I'm thinking melted cat is the most likely problem.
Also another thing that he mentioned, my O2 sensor was causing the car to run like crap so he has left it unplugged. Any ideas why it would run like crap with the O2 sensor plugged in but run fine with it disconnected?
No issue, if its tuned around the cruise etc it wont make a difference in fact may return better economy..
We are having a few issues with rb25's having soft valve springs... more boost introduces a weird power drop. Replace springs and bingo all good but the r34 is usually no issue and it usually happens around 280rwkw
Couple of thing that is extremely important.
1. After turbo installation do check pressure leaks ( I can supply 2x simple steel plug with a hose nipple for $50). Turbo will not perform if there are leaks.
2. Most of our turbos are installed with a 18psi high pressure actuator. by pass all boost controlling devices on test run, Boost gain from EBC based on stock actuator will cause massive boost creep.
3. Make sure the car's got a at least 3inch metal induction pipe with pod filter. Do not run those metal stuffed stock intake pipe.
4. An good exhaust system should restrict no more then 10KWs (My HKS silent power made 3KWs restrictions on a 316rwkws application). So Dyno tune with cat and exhaust dropped, (front pipe only). Do a touch up run with exhaust on after tuning, Get a better exhaust if you see a massive power drop with exhaust.
If above procedures are followed you will definitely get the desired power goal.
Also people with RB25det R33s. pay attention to those 20 years old valve springs and valves. Mine were all chewed out and worped possibly from valve float. That will act as boost leak, causing lose in power and response. Recommend stronger valve springs.
From what I have seen this is a common issue guys.
I think all people wanting to push more than 250rwkw reliably should consider a valve spring upgrade.
Over the past week and a bit, I've lost quite a chunk of my power. At least it feels that way, given how rarely it lets go in 2nd when I plant it....
I wonder if I'm suffering from this? :(
Check valves. Same happened to my car. Engine felt very strong with crisp throlle response after rebuild. That slowly went away and felt worse after each dyno run. Been told by engine builder this is due to unsealed valves, mine were all under 40%.
yeah it's probably a mix of all of the above. Either way, still feels strong, just not stupidly strong like before. Plus I'm pedantic, and I worry too much, and I suffer from automotive-hypochondria.
lol.
hi stao
what have you done to your head?
which parts e.g. valve springs?
cheers
simon
Well I don't want any thing that could alter the performance of a stock RB25det. So it will still be a stock head with stronger valve springs.
have you chosen a brand and type yet?
cheers
simon
    • All trim back in wired running driving. Few things to follow up on but not far off the return to the road. att.6HN4wP38LTIOISkhA8eACoBFqzfgQMahZPLA8ut0pqE.mp4 att.w2q0ux2PGuqgQTj2Os13cNHQtqcSEcCAhD_CAXy_IQM.mp4
    • The trouble with phone apps is that they really do not know the sensitivity of the mic on each specific phone, whether there is some sort of cover or skin that can change that, etc etc. So the readings off them are not calibrated. You certainly couldn't be sure that you were even within 3 dB. I have the same app on two (actually more than that) different phones/tablets and the readings in the same room at the same time are never the same. I don't mind the apps - they are as useful as a dyno - if you're testing for delta from thing1 to thing2. But not to try to generate some sort of absolute value.
    • I'm gonna use the "Sound Meter" app from the Google Play Store and as close as I can bother to these procedures: 4. TEST METHOD FOR ALL VEHICLES EXCEPT PRE ADR83 IN-SERVICE GOODS VEHICLES AND OMNIBUSES 4.1 Microphone position 4.1.1 The microphone shall be directed towards the orifice of the exhaust outlet and shall be supported by a tripod or similar device not providing excessive acoustic reflection. The general requirements for positioning microphones are shown in the Appendix. 4.1.2 The nominal axis of maximum sensitivity of the microphone shall be substantially parallel to the test site surface and shall make an angle of 45 degrees ±10 degrees with the principal direction of gas flow from the exhaust. 4.1.3 In selecting the 45 degree alignment from the outlet of a motor vehicle fitted with two or more outlets, only the angle resulting in the microphone being farthest from any other outlet must be used. National Stationary Exhaust Noise Test Procedures for In-Service Motor Vehicles Page 3 4.1.4 The height of the microphone above the test site surface shall be equal to that of the orifice of the exhaust outlet ±25mm but shall not be less than 200mm above the test site surface. 4.1.5 The distance of the microphone from the exhaust outlet orifice shall be 500mm±25mm. 4.1.6 [Relates to vertical exhaust outlets] 4.1.7 For vehicles fitted with one exhaust outlet the microphone shall be placed so that the greatest possible distance is achieved between it and the vehicle. 4.1.8 [Relates to multi exhaust outlets] 4.1.9 [Relates to multi exhaust outlets] TLDR: 200mm off ground 45 degree angle relative to exhaust flow 500mm from tailpipe exit. (I probably won't use a tripod) Here's a photo, cause I read the instructions wrong myself.
    • No ABS, no TCS, no airbags, no cruise control, no lane departure assist, no emergency brake assist, no orange lights in the mirrors (continuously annoying me in multi-lane traffic), no stupid rear view camera. I am the one responsible for where my car goes and how it does it.
    • Cheapest Jaycar one is only $65.
