This update is for the current ATR43SS with FNT turbine, which we will refer that to ATR43SS-1, and the other one made 320rwkws we will refer that to ATR43SS-2
This is first run high pressure actuator only wastegate controller off. I think this actuator is abit too stiff for this turbo, but thats all I had for the day. They will be equipt them with a 14psi or 7psi actuator.
Run below is based on 9 sec ramp timing.
Now with a manual boost controller set to 24 psi maxing out the turbo.
If you can get those results with the standard housings you will have a killer turbo.
GCG managed it with a shitty rb20 turbo, less boost (18 tapering to 15) and around ~10kw less. Why is the larger compressor housing needed if its only flowing ~245kw ?
The reason I ask is if you are going to change the compressor housing you might as well just get a garrett gt3076, the only reason imo to use a highflow is so it looks stock.
Edited by Rolls
The stock housing is in .60 identical to the one that I've used. Except factory housing's got a 2.5inch inlet and this one has 3. End result should be very similar.
How ever turbine side is running .64 single nozzled FNT setup. stock or normal housings will be slightly off down low and mid range, but nothing major. I think this turbo should be excellent for RB20det motor or rb25 people whom chasing responsive 250rwkws.
Hey hey,
I bought an ATR43 G3turbo + 1.7KGactuator off you a couple months back for my 1jz build... anyway, things are progressing slowly so I have some free time; Would you be willing and able to upgrade the rear housing of my turbo to the "tri-nozzle" design still capable of ~300rwkw (my power target), with as much response as possible in attaining that.
Cheers,
Matt (same name on NS, if you'd prefer to PM)
I can do the single nozzle, Tri nozzle is still on abit of research. Cost $150 to carry that out. Probably won't worry about it if its a auto tho.
Is the ATR43SS-1 a ball bearing turbo? If it is will you be offering a plain bearing version?
Throw a stock compressor cover on, can leave the 3" afm in factory location with a 3" metal intake pipe (instead of relocating afm into cooler piping and 4" intake on 0.7 compressor cover). This should be your number 1 seller, factory appearance, cheap and a responsive 250-270rwkw.
Note: That dyno goes to 7200rpm so reduces the amount that the power falls over up top.
This turbo has double the torque of mine at 3,000rpm and about 80% more from 3500-4000 then similar from there on, with only a 10rwkw difference at redline!
I believe the SS-1 to be an excellent option for customers looking at buying a GTRS without the price tag, and the SS-2 for the same market looking at a Garrett 3071 or similar.
To the one that made the highflow comment, these turbos are not highflows - you do not need to send Stao your stock turbo for him to send back an SS. You can simply buy the item which will utilise the stock dump config and is stock manifold friendly.
Stao I think your current range of products are becoming very hard to surpass for value. Make sure that SS-1 is affordable and im sure you will sell them like hot cakes.
You are correct, however if you desire you can send in a standard nissan compressor cover and Stao can use that so that the turbo still appears factory from the front. That is what I did for mine. Will take a cop that really knows his stuff to notice the difference in exhaust housings.
I think the standard compressor cover starts to limit things if your pushing up to 300rwkw but on the SS-1 it would do the job well.
I would say it would only make around 290rwhp or 215rwkw on a RB20
Hmmm really?? I would have thought considering it is a small/medium size turbo on an RB25 then it would be a medium/large size turbo on an RB20 and it would make say 230rwkw but with more lag obviously.
For example, on an RB25 it makes just more than a GTRS. What power does a GTRS make on an RB20?
The SS-1 is expected to make 200~230rwkws mark on a Rb20det with excellent street driving ability with supporting mods depending on engine condition, tune and etc.
The SS is engineered for street driving ability, So smooth and fast rid would be considered prior then a super powerful machine.
Well that graph has STP correction on so I would imagine it's only really making about 250rwkw without the correction inflating the figures...
RB20's generally make 20-25rwkw less than RB25's and usually take 4-5psi to make that power, so on the same boost I would expect around 35-40rwkw less
Interesting, I notice my dyno has SAE correction. I wonder why Trent would change it?
In post #1499 mine is the light blue graph and yet the comparison says STP correction so the green graph must use STP.
I'm not sure the affects of STP corrections, Seems cars dynoed before or after mine on the same day were running the same configurations. Had a Soarer that day whom came in for 2nd opinion which pulled within 1kw from a roller dyno.
Trent would not deliberately alter his dyno for happy results unless current STP configuration produces more accurate reading in real world. I will speak to him about it and possibly do some comparison runs next week.
Of your readings SAE have made more power thou.
I have actually confused STP with the SAE correction which when we put on was giving very happy results...
STP I would assume is standard, temperature and pressue?!?
So it might not actually pump up the figures as much as I suggested!
    • HPA do an interesting video on tuning, and Adrian shows on the dyno, moving from 10:1 to 12:1 (And I think even 13:1) and the power moves SFA. However, a couple of degrees of timing has a HUGE impact. Exhaust side of things will more be the length of the exhaust and how many bends and turns you have. The straighter you can keep it, the better. By a lot. Oh, and getting the diameter right. Bigger isn't always better. Going to big can actually lose you power.
    • I have to say, most people I see on the road fit the bill of atrocious drivers. Whether they be cowboys in their dual cabs, bogans in the Commodores, or the soccer mums. Pretty much most people on the road put zero freaking thought into driving. Barely look further up the road then the end of their bonnet, and have never even thought about how catastrophically wrong shit can go, by doing what they all deem as normal driving. Especially their late braking, racing to stopped lights, and sitting half a foot off the bumper of the car in front at 110km/h. Wanna know what's even better? By the time their kids get to be old enough to learn to drive, they've already got in the back of their brain what is normal driving, how annoyed you're allowed to get at people etc, and then their parents who actually have zero freaking skill at driving (Even though they constantly say "I've been driving for 20 years and never had an accident!") teach the little twerps how to drive, or should I say, how to make a car move. Literally watched a parent teach their L Plater, on a 4 lane freeway, that you just slam the brakes on, and push your way over, even with a B Double bearing down on you, and that's how you should drive, rather then, just keep going to the next exit. Same shit happens all the time for side streets etc, watching numpties pull dumb shit turns pushing across 3 lanes of traffic, rather than just go up the road another 30 seconds, and take the next turn that'll get you to the same location... Oh, and the damn right lane bandits. Or the retards driving along with their headphones in, and can't hear the ambulance or fire truck right up their ass about to run them over...   Pretty much, people drive on the road, like ego centric f**ks, and don't actually think how dumb shit their driving is, how it could easily kill them or someone else in a split second, or at the very least, how they're driving is contributing to all the shit they're bitching about on the road, like shitty congestion!
    • Yeap, not as doorty as ITB's, but alot more doorty than before, induction sound great when I'm up it 馃
    • Any difference in induction noise?
    • I think you know exactly who I mean.
