I know this isn't the place for this question, but this is as good of a time as any to ask it....
I don't understand the point of "corrections" on a dyno. The car makes X power. End of story. It made a specific figure, why should that be altered "just because"?
It sounds similar to someone trying to give you the temperature, but adding on (or subtracting as the case would be) wind-chill. That isn't accurate, and shouldn't be counted.
Same goes for different corrections for 4 cyl, 6 cyl turbo, 8 cyl, etc. WTF?
its good, but only the second Dyno graph which the boost is set at 24psi! Im looking for a Turbo like this one, but only pushing out 15-17psi, 200rwkw at 4Krpm 260rwkw max.
thats this one but i dont want to be putting 24psi to be making it.
At this stage the ATR43SS-1 is the only turbo managed to hit 205rwkws on 4000RPMs based on 9 sec ramp timing on Status dyno (with stock setup, 98 fuel, etc etc).
You can run a larger turbo with less boost on 12 or 14 sec ramp timing to get similar result, but that doesn't necessarily represent it on every day road.
With 17psi using a boost controller it should hit the 180~190rwkws mark at 4000RPMs.
The only reasons why "high" boost will break a motor is from either the turbo being out of efficiency hence detonation from higher charge temps, or because it's simply too much power.
Yeah psi isn't what kills a motor, its torque figures (combustion pressure) and temperature (intake charge temp due to compressor being out of efficiency). Then the usuals like detonation, running lean etc.
Next up the ATR43G3 Alfa version. With Duel ceramic ball bearing and penta nozzled FNT turbine housing. Unlike traditional ball bearing cartridges this one runs a splashed oil delivery setup instead of concealed force feeding setup. This is unlikely to suffer from minor oil contamination related issues. Will be testing next weeks and hopefully every thing go according to plan.
This is also the very first penta (5) nozzed FNT turbine housing, should produce more down low torque with better mid range.
Short video:
http://www.youtube.com/watch?v=t0tBzdAqQBM
I would like to see the differences that additional nozzles makes. FNT nozzles swirls the air as it enters the turbine housing, but too many of it can cause flow restrictions. Note how the turbo spooled with just bit of air shoot through the turbine inlet, I could not get this effect with traditional turbine housings. I’ve been waiting to see this with the effects of ball bearing rolling objects.
the correction is included (you can elect not to use it, ie non shootout mode)
on the dyno runs to standarise the measurement
so if you dyno a skyline in australia on a 20deg day at whatever sea level pressure
then dyno the same skyline in dubai with 48deg day on whatever sea level pressure
you can accurately compare the two
otherwise without the correction the one in dubai would be well off due to the excessive intake temp
I'd figured it was about this, but what shits me about it is POWER IS POWER. There's no point in saying "this is how much power it WOULD have made given different intake temp etc". It's just stupid. It made a certain power. End of story. You could have a correction that could potentially make it have +50% of the power it actually made. In that case there's no point even showing a power figure, as the dyno is good for nothing but a stationary way to load the engine for tuning.
Sorry just a rant, there are many things in this world that are just f**king stupid lol
but its there to normalise the results
so that if you dyno your car in darwin in summer and make whatever rwkw
and you compare it to another skyline with the same turbo in winter in tasmania
that way with correction you both make roughly the same power
if all things are equal and both engines ie are the same etc
without correction
he makes tons more
you make tons less
and you think his is either super quick
or yours is super slow
It's purely to allow comparisons. That's it.
That and for if you drive your car from Darwin to Tasmania that you don't crack the shits you "lost 50RWKW"
In reality you might be up or down power elsewhere at that single point in time, but if you hold intake temp constant along with the pressure and humidity, you will make the same power no matter where you are.
Got the ATR43G3 Alfa model installed today. Took short video footage of it on car during idle and switch off:
I'm still running the 265rwkws tune from SS-1. Its obviously not as responsive but pulled lot harder up top, I'm expecting it to perform similar to ATR43G3 with better down low and mid range. will post results once finished.
Also stock exhaust manifold doesn't seems capable of flowing 330rwkws+ regardless the difference in size of turbo. This turbo going by specifications should crack 550HP. Will consider to upgrade manifold soon. Or send in a pm if any one’s got a good conditioned custom low mount for sale.
To build it brand new from scratch will cost $1560 inc GST, takes roughly 3 days to complete. Couple of manufacturing steps involved and many man hours required. I've pmed you an offer for the one that came out of my test car. please check and reply if interested. Thanks.
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
