Gtr Crash Chasing Evo Ix Mr
ashneel
 Share
It is hard to tell for sure being night, but the GTR driver looked way out of his depth.
Lucky he crashed at that early stage of ownership - otherwise a tree would have
killed him on another road. It was the car committing suicide rather than put up
with the owner.
as for the evo driver, he shouldn't be bragging about his role in it all.
well the evo was pretty rapid and sounded pretty tough too. considering the R35 driver nearly understeered off the road on at least 2 corners during the run you'd think those brown moments would have caused him to have a little think about what he was doing and draw the conclusion that he was way out of his depth and driving at speed well above his skill level and just pull things back a notch and drive normally. but for some reason his brain doesn't seem to have that capacity. the real crime here is the knob will probably just file an insurance claim and get a new one which of course comes out of the pocket of all the sensible drivers his insurance company insures.
I'd say he didn't engage the 'driver has a brain' mode and he also forgot to switch on the 'stop car understeering when entering corners too fast' mode. also VDC can't save you from understeering into a wall.
'DHAB' mode was only available in JDM models :P
the guy says his evo was stock
NOTE!!! my evo is STOCK!!!, i have a straight pipe from the cat back, used tein flexs with semi blown valves, and a k&n air filter, not intake, just filter. running azenis tires. NO MOTOR MODS, STOCK HORSEPOWER.
lol. VDC off. TRC off. DHAB off.
You know in one part where the car was lit up by headlights I could swear the bloke driving it looked like mines_datsun... and I swear that wall had a queue of people standing behind it waiting for a bus... coincidence? I think not.
They all claim that,
Though it doesn't really matter what you drive, its the driver.
another reason why you don't put GTR's anywhere within reach of idiot American kids. See what you've started Carlos?
On the upside... more spare parts.
It isnt the sole domain of american kids either. :ermm:
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
