It is hard to tell for sure being night, but the GTR driver looked way out of his depth.
Lucky he crashed at that early stage of ownership - otherwise a tree would have
killed him on another road. It was the car committing suicide rather than put up
with the owner.
as for the evo driver, he shouldn't be bragging about his role in it all.
well the evo was pretty rapid and sounded pretty tough too. considering the R35 driver nearly understeered off the road on at least 2 corners during the run you'd think those brown moments would have caused him to have a little think about what he was doing and draw the conclusion that he was way out of his depth and driving at speed well above his skill level and just pull things back a notch and drive normally. but for some reason his brain doesn't seem to have that capacity. the real crime here is the knob will probably just file an insurance claim and get a new one which of course comes out of the pocket of all the sensible drivers his insurance company insures.
I'd say he didn't engage the 'driver has a brain' mode and he also forgot to switch on the 'stop car understeering when entering corners too fast' mode. also VDC can't save you from understeering into a wall.
'DHAB' mode was only available in JDM models :P
the guy says his evo was stock
NOTE!!! my evo is STOCK!!!, i have a straight pipe from the cat back, used tein flexs with semi blown valves, and a k&n air filter, not intake, just filter. running azenis tires. NO MOTOR MODS, STOCK HORSEPOWER.
lol. VDC off. TRC off. DHAB off.
You know in one part where the car was lit up by headlights I could swear the bloke driving it looked like mines_datsun... and I swear that wall had a queue of people standing behind it waiting for a bus... coincidence? I think not.
They all claim that,
Though it doesn't really matter what you drive, its the driver.
  funkymonkey said:
another reason why you don't put GTR's anywhere within reach of idiot American kids. See what you've started Carlos?
On the upside... more spare parts.
It isnt the sole domain of american kids either. :ermm:
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
