Gtr Crash Chasing Evo Ix Mr
ashneel
 Share
Ouch! As others have stated he was clearly out of his league. Why he didn't back off a bit and drive to his abilities I don't know, especially in a car that isn't his.
Can someone please explain why both of these fools don't get arrested for the US equivelant of dangerous driving, racing and careless driving? If that happened in Aus they'd both be crucified and it would be all over the news.
I like to give my car a squirt every now and then just like everyone else, but FFS public roads are not for racing!
Obvioulsy VERY inexperienced driver cause as soon as the Evo stopped giving him the driving line and braking times he went RIGHT OFF THE ROAD!!!
That was painful to watch, he should of slowed down he almost lost it twice mid way before the crash.
lol it wasn't the driver, the GTR just went "f**k this guy is a shit driver, i'm gonna put myself out of my misery"
didnt the guy's youtube profile page say he's running "3" twin scroll turbos and direct port nos???
looks like someone got a pre-release copy of the 4th fast and furious movie
well the evo was pretty rapid and sounded pretty tough too. considering the R35 driver nearly understeered off the road on at least 2 corners during the run you'd think those brown moments would have caused him to have a little think about what he was doing and draw the conclusion that he was way out of his depth and driving at speed well above his skill level and just pull things back a notch and drive normally. but for some reason his brain doesn't seem to have that capacity. the real crime here is the knob will probably just file an insurance claim and get a new one which of course comes out of the pocket of all the sensible drivers his insurance company insures.
I saw this on TMR - Tragic.
Totally agree with Richard; he had at least two 'moments' before his off, that is plenty of warning to back off, he was out of his depth. Can you imagine if that rock wall was less solid? It looked like a mountain pass pretty high up; probably a sheer drop on the other side.
And the pic of the evo at the end was just ghey.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
