Hi all, i have bought an ARC 135mm racing intercooler. Currently I run an ARC 105mm intercooler. I remember i when i installed the 105, there was a quite little bit to chop off both the bar and the reo. I'm a little concerned now, is 135mm possible? Will she be able to take it? Can you please share your experiences with thickness? How did you deal with it? How much blood sweat and tears were involved? and what did she look like afterwards? Pictures of yours would be great!
Hi i dont have pics but i can say that i installed a 149mm trust tube and fin cooler on the R32 GTR had to shave the inside of the bar to suit which really wasnt that hard, the reo has to be shaved also along the outer edges where the cooler tanks are but again with a small grinder and a little patience you can achieve it easily. Took me 4.5 hrs to cut bar and reo do some dummy fitting etc.
Hope this helps good luck.
On a side note Atomic Bomber Man, is your current 105mm thick core twin entry? and also would you be looking at selling the core :D
It should be sweet though, air saws are wonderful things ;)
I ran an Apexi GT Drag Intercooler on my R33 which had a core thickness of 136mm and had no problems.
There was some trimming needed but the factory bar went back on and I was also able to refit the factory mesh.
mr gtr, is it possible to get pics? does it stick out ver far? i am more concerned about the look of it. i have a feeling it might look a bit funny. ie the cooler protrudes through the hole it should be sitting behind! :D
weapon, the i/c is not twin entry, and i have already sold it to a friend. fantastic looking bit of gear they are. well designed too!
does anyone have pictures of thick ones?
atomicbomberman i will try and dig up pics of the cooler installation, i shaved the reo bar and its still all there in perfect condition, the cooler looks fine does not come forward thats the whole reason of shaving the reo bar at the required angles to accomodate the thicker cooler tanks. In regards to the air con fan i did have this probelm but was able to keep mine with some gentle persuasion i was able to slightly push forward the metal grille shrouding so that the fan would not rub on it as i was not going to sacrifice not having a/c. The fan will be only 5mm away from the cooler but will pass i have never posted up pics on the forum as im not very computer literate but if you pm me your mobile phone number i can sms some pics with my phone to you so you can get the idea.
cheers,
Dave.
ive had a few through with the big daddy (165mm) trust coolers.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
