I have a little problem.... My mate just bought a 2000 model R8 clubsport and is convinced it is faster then my R33 so we are taking them down to Calder to see for sure. The problem is i dont want to look like a fool if he destroys me.... any one have any ideas on how it will go?
here are the specs:
R33: series 1, lowered, air filter, exhaust system (3.5"), boost up to 12psi.
R8: Stock, 250Kw, Auto
I recon he is in trouble but want to get some opinions from people who have run against similar cars.
https://www.sau.com.au/forums/topic/26162-my-r33-gts25t-v-2000-r8-clubsport/
  • Replies 56
yeah..... i know and he even tries to tell me that the holden traction control button on his dash will work like a F1 launch control box...... i really have to beat this guy, i may just wind my boost up to 20psi for the 1/4 mile run and just pray that nothing explodes.....
The tests quoted by magazines are based on a g-tech so they are very optimistic
Dont Wheels and Motor use Correvit timing, i was under the impression that this is highly accurate, only they time the cars with half a tank and a passenger so typically carrying approx 100kg additional.
As for his car being quicker... dont worry. Look at it like i do.
Not many of my friends are into cars, but typically those that are all have quicker cars... I love it, they get to spend all their money on getting their cars going quickly, and i get free entertainment joyriding in them.
He drives a Commodoor does he? Mmmmm.....
Could you ask him (and say Rezz from Japan wants to know),
HOW THE F*CK DOES HE KNOW WANT AN F1 LAUNCH CONTROL BOX IS LIKE? :looney:
Good luck, I hope you beat him:D
I am feeling a bit more confident now.... i still think it will be close, but if i lose it wont be by much and i can still give him shit for paying $35g for a car thats just faster then my $14500 car that can go around corners as well as drive in a stright line.
Yep highly accurate for a Correvit timing run Not a real dragstrip. The times are always a little too generous.
Guest Robo's
Dont get me wrong i love the skylines, but the LS1 motors are very good and make impressive power outputs. With the computers now cracked, 230rwkw is not uncommon with just tune and exhaust mods to LS1. I know they are heavy lumps, but with the added power, they can be still quick. My mate has ran 13.1 in his VX SS, 6 speed with no internal mods.
But seeing as this ones an auto, the autos slow them down alot as they LS1 loves to rev, so the stock R8 being an auto, you should hand it too him. Good luck anyway!! Its all fun.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
