Hot As R33 250rwkw
Now yes I have already posted a thread, but since you are unable to edit threads for price change etc. I have decided to make a new thread
Cheers
The time has come to sell my baby, where I'll be moving doesn't have secure parking so I've decided the time has come to sell my pride and joy.
93 GTST.
Mods:
18" rims
trust front bar
impul r34 side skirts
impul r34 rear bar
drift lip wing
custom red
series 2 engine 100,000km
blitz front mount
blitz neuro spec V exhaust
kkr Turbo
dual stage boost contoller
walbro fuel pump
Nismo fuel reg
splitfire coils
blitz BOV
apexi safc 2
bee*R Rev limiter
dyno proven 250.2kw at the rears
Apexi Coil overs
2 way lsd
rda slotted rotors
ferodo ds2500 pads.
Complete package one of the tidiest examples around, goes well, handles well, stops well you can't go wrong!!!
Car is currently in sydney but has ACT rego custom plates "Y TR1 33" plastic slim line black and white
Chasing $14000 o.n.o
pm
or
0420 243 038
cheers
16 psi it does have a slight drop off before max.
It's daily driven at 14psi and pulls 241 with a perfect power curve.
Results we're done by trojan in mitchell ACT I believe they used gus' dyno which is used for a little of runs in canberra.
Add after market injectors and a powerfc she'll pull 270-280. The KKR turbo's work great for some reason got a mate with a 32 running the same setup pulls pretty much the same
Edited by Darkon
amazingly yes. If you know rhodes shops at all I've had no problems getting in the underground car park or going up on the roof. Also going up the levels at burwood Westfield. I wouldn't recommend flying up and down ramps, speed bumps etc but with a little bit of care theres usually no dramas. It sits pretty much on the 100mm never had an officer question the height at all. A few have actually said it's a awesome looking car lol
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
