Wanted, Good pair of Used tyres, 18" 265/35
I admire your efforts with the scuff pad. As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling. Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint. Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas). At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process. -
Unplug it and see if the car makes a difference -
Much love, no homo. -
Merry Christmas labibi
