  • Replies 42
If you read my post i said it is EITHER a non V-spec car OR the klm's are not correct , so if the car is a genuine V-spec it is obvious the speedo cluster is not from that car and has been replaced for a speedo cluster from a non V-spec car so the klm's are wrong i was pointing this out to any potential buyers of this car because OS30GK and yourself were so adamant it was orginal milage
please keep personal comment to yourself and YES it is a FKN V-Spec!
Hi I cant seem to send you a PM, I am in Bunbury coming to Perth end of week or so - I would like to have a look at the car, I am after a VSpec. Can you either send me an email to [email protected] or call me 0417943522 so we can catch up
thanks Mike
need this GTR gone this week moving Interstate. worst comes to worst i will take it to a car yard and see what they give me, OFFERS!
It's a 95/09 build date.
Also comes up GTR/V so that should confirm it's a V-Spec but to be on the safe side check the VINS you want "fasted" thread.
http://www.skylinesaustralia.com/forums/VI...ed-t128496.html
Thanks for posting that. I've been searching and sniffing for a early '95 v-spec build to import. I've struck out so far with june and september. THanks though, i appreciate it.
Don't do that, they will give you 15k at the most.
Better off taking it with you and holding off a little longer, you will sell it, it's just a matter of time....
Neat car with tasteful mods.
Good luck with the sale...
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
