  • Replies 42
If you read my post i said it is EITHER a non V-spec car OR the klm's are not correct , so if the car is a genuine V-spec it is obvious the speedo cluster is not from that car and has been replaced for a speedo cluster from a non V-spec car so the klm's are wrong i was pointing this out to any potential buyers of this car because OS30GK and yourself were so adamant it was orginal milage
please keep personal comment to yourself and YES it is a FKN V-Spec!
Hi I cant seem to send you a PM, I am in Bunbury coming to Perth end of week or so - I would like to have a look at the car, I am after a VSpec. Can you either send me an email to [email protected] or call me 0417943522 so we can catch up
thanks Mike
need this GTR gone this week moving Interstate. worst comes to worst i will take it to a car yard and see what they give me, OFFERS!
It's a 95/09 build date.
Also comes up GTR/V so that should confirm it's a V-Spec but to be on the safe side check the VINS you want "fasted" thread.
http://www.skylinesaustralia.com/forums/VI...ed-t128496.html
Thanks for posting that. I've been searching and sniffing for a early '95 v-spec build to import. I've struck out so far with june and september. THanks though, i appreciate it.
Don't do that, they will give you 15k at the most.
Better off taking it with you and holding off a little longer, you will sell it, it's just a matter of time....
Neat car with tasteful mods.
Good luck with the sale...
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
