s13 coils bolt straight in. only mods is machining out camber tops to actually gain - camber or get dr30 camber tops.
So I can just buy a set of S13 coilovers and using leftover bits from my DR30 struts make it all fit front and rear?
https://www.sau.com.au/forums/topic/261648-dr30-coilovers/#findComment-4485481
you may as well do an s13 front hub conversion.
the rears will fit the trailing arms but you will need to buy different caps coz silvia run two bolt.
OR you can precisely drill out two new holes in the top of your strut tower, but it would be better to find proper top caps.
https://www.sau.com.au/forums/topic/261648-dr30-coilovers/#findComment-4486041
5 stud conversion really can be done, anyone have an idea for doing rear 5 stud conversion?
S13 coilovers yes they bolt in you just take the plate off that the standard struts bolt to the LCA onto...If you run the standard S13 camber tops be prepared to run alot of negative camber or run the DR30 strut tops
https://www.sau.com.au/forums/topic/261648-dr30-coilovers/#findComment-4486226
the advantage for me was a floating disc set up and coilover fronts with more options.
100mm spacing for bigger brakes, mine is an mr30 not a dr30.
i have the understanding that dr30's already have this 100mm spacing?
makes it a whole lot easier to take your front shocks out!!
https://www.sau.com.au/forums/topic/261648-dr30-coilovers/#findComment-4486697
sorry should have been more specific, as said will need s13 hubs of course to bolt the coilovers to (s13 r floating hub and have strut separate to the hub). but all that bolts straight in (have s13 shit on my dr30) even brake lines fit straight up. only thing is that the steering knuckle on s13 hubs is thicker so when u screw the nut down it wont line up with the hole 2 get a split pin thru. can just put the nut upside down so can still get a pin thru. wont b able 2 come off, mines just 4 track work anyway.
and yea just drill out the strut tops for the rear. i just marked them out with pair of dividers no dramas.
or also as said could get proper 3 stud strut tops from somewhere.
Edited by OUTATIME
https://www.sau.com.au/forums/topic/261648-dr30-coilovers/#findComment-4487260
yerp your right DR30's have 100mm bolt spacing for the calipers so changing to S13 coil overs is really not needed...if your really in need for coil overs sleeve ur standard struts easy as
https://www.sau.com.au/forums/topic/261648-dr30-coilovers/#findComment-4487322
you can counter sink a hole the width of the nut in the top of this hole so the nut will screw down all the way.
only needs to be counter sunk about 3mm, then it works a treat. no need for upside down nuts or ball joints with no split pins.
https://www.sau.com.au/forums/topic/261648-dr30-coilovers/#findComment-4487759
if you're not in a hurry check out importmonster.com.au
i bought a full set of r32 gtr calipers, they also happened to come with brand new pads too, for 17,700yen which was about 170 bucks at the time.
i also got a full set of coilovers to suit the s13 conversion for 20,000yen which was about 200 bucks.
Edited by skybt1
https://www.sau.com.au/forums/topic/261648-dr30-coilovers/#findComment-4491430
i have been wanting to try and see if you can fit z31 stub axles into the r30 items.
but it is a rare item and im not even sure if it will work.
then you can use the z31 half shafts which are way better.
that would be good, my shafts are flogged and need to rebuild or upgrade, not so easy. ive seen 1600s with r200s runnig commondore halfshafts dont no if can do to r30 ?? .. i no its commoncrap but strong
https://www.sau.com.au/forums/topic/261648-dr30-coilovers/#findComment-4512747
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
