im planning to service my brake fluids soon and i was looking at motul rbf600 (dot4) brake fluid , is this any good?
i asked a mechanic and he recommended i go for dot 5.1 from the motul range
http://www.motul.com.au/product_line_up/fo...s/others05.html
not sure on what brake pads and such the car currently has as it was recently purchased only
car is a 1993 R32GTR
car would mainly be driving on the street and the odd spirited run
https://www.sau.com.au/forums/topic/261659-brake-fluids/
The fluid we use and recommend is the TRW GP600 brake fluid:
TRW GP600 Dot 4 Racing Brake Fluid
Dry - Min 310
Wet - Min 204
That's about the best out there short of Castrol SRF, or GS610. But significantly cheaper than either of them at $65 for a 1L bottle.
For comparison, some other popular brands:
Motul Dot 5.1
270 dry
185 wet
Castrol Response Super Dot 4
286 dry
184 wet
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4484921
  • 1 month later...
Do a proper flush (out of the lines and abs unit) before putting RBF600 or 5.1 in or it defeats the purpose of putting them in, most likely just have standard DOT4 in there currently.
Flush it well when switching to RBF600 or 5.1 to 4.0 or vice-versa, there are known issues that some brake fluids aren't supposed to be mixed together...
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4585900
The beauty of the TRW GP600 I talked about above (apart from having better performance than the Motul and generally being cheaper anyway) is that it's Dot 4 compatible. So rather than use the expensive stuff to flush it the system out, you can just grab any $7 bottle of Dot4 from the servo, use that to flush the system out, gravity drain, then top up with the good stuff.
The problem with the Motul gear is that generally it's not Dot 4 compatible, and you cannot afford to have any of the old fluid left over...
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4589062
Look, with all due respect Motul RBF 600 and/or 660 IS A DOT 4 FLUID.
It is therefore compatible with other dot 4 fluids.
There is no good reason to use dot 5.1 fluids, Motul or otherwise. The dot 4-600 range perform better, ie have a higher boiling point. The hint is that the 600 (or 660) term in the title is a reference to its boiling point in degrees fahrenheit.
The reference is here:
http://www.motul.com.au/product_line_up/fo...s/others04.html
http://www.motul.com.au/product_line_up/fo...s/others03.html
Fresh fluid (of almost any description) is as good as tired RBF600 fluid. You lose approx 100 degrees celcius out of the boiling point when the fluid is old & wet.
Edited by djr81
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4589078
I have found the Castrol Response Super Dot 4 great for street duties, at around $10 a bottle its cheap and will not boil easily.
Used the same stuff on the track and as a new (ie. slower) track driver its sufficient, but its not very hard to overheat it.
Bought some Penrite Sin which is rated to 310deg Celsius dry boiling temp, its $20 from Repco so I thought I would try it at the next track day instead of the Motul stuff at $25-30 per bottle.
Anyone had experience with the Penrite fluid?
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4589094
I've used the Penrite Sin fluid in my GT-R, found it to be good.
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4590305
yeh i saw that down a ABS when i grabbed my pads.
my only concern is that (not knowing) the current fluid in there could be silicone based. This will be the first flush since bought that car earlier in the year.
edit: that current stuff in there atm wont be that great. as the brakes only last 3 laps.
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4591148
Thanks, what are you comparing with, i.e have you found it the same as rbf600 etc?
I've used both. I didn't notice any difference.
The sin is cheaper and my local repco has it. win win. Not knocking the motul product as i have used it for a couple of years with no issue, just don't feel like a half hour trip just to get some any more.
As mentioned above, both are dot 4 compatible so none of the issues of switching to a dot 5, just bleed it through.
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4592582
Thanks for the reply. As of last night I have the fluid in my car and am using it this weekend :( Will post up how it performed afterwards.
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4595340
Update:
Used Penrite Sin with DS2500 pads at Wakefield, fluid did not overheat at all during my 4 sessions.
Previously have only used Castrol Super Dot 4 (silver bottle) at the track, that would hold up ok but would overheat a bit (never overheated it on the street) keeping in mind I flush or bleed it before and after any hard use so its always fresh.
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4600796
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
