Hey guys after a set of forged pistons for my rb25det. Would prefer std bore size but really offer me whatever you might have. Also after a set of forged rods. Not fussy on brands, as long as they are in good condition and reasonably priced. Also after a new headgasket (some form of multi layered steel) Whether it be cometic or hks etc. Let me know
Pm but prefer txt message to 0415 773 334
Ok guys. Have got my pistons now, so Im still chasing everything else. Let me know if you can help me.
PLEASE NOTE: NEED A BIGGER BORE HEADGASKET (88/88.5MM) AS I BOUGHT OVERSIZE PISTONS
Edited by Jamie88
Hi Jamie,
We have brand new Autech ATTKD Forged Conrod Sets in stock for RB25 in both I-Beam & H-Beam, starting at $699.00 per set.
Both types are available online via our website by following the URL below:
http://justjap.com/store/home.php?cat=382
If you have any questions, please don't hesitate to ask.
Regards,
Steve
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
