Many may have read the current FF article on athids car (front cover S15) and how i rate the TD06-L2 as the best SR20 (rb20 too for that matter) turbo package, Well today i had the pleasure of playing with two on a 2JZ :D
This car firstly is a credit to its owner and the builder this tough street driven 2jz it was spot on. All runs on 98 PULP
Motec M800 and CDI (dream to tune with)
Full Forged 2JZ
Greddy intake plenum
BIG cams
Sard 1000cc
Titan fuel hanger and pumps.
Tuned up 426.3rwkw@16psi but pulled this particular recorded run early @ 7000 (normaly we pulled to 8000rpm), then dialled up some boost and had to call it quits 579.4rwkw@7100 due to injector duty topping out (6800rpm) and afr was heading rapidly Northward towards the danger zone i reckon with another 1000rpm and a bit more boost 600's would be a walk.
Edited by URAS
  • Replies 41
Maxed out 1000cc injectors - good stuff. Although shouldnt 1000cc's be getting a slightly higher figure before maxing out? Or was it fuel pressure dropping that made you stop?
Any details on head work, cams etc?
Largest Jun items, full valve train kit. Fair amount of port work too. As for exact specifics i cant remmeber (last time i posted up specifics i got it wrong and got flamed.... r34 stylez :D )
possibly looking to put 8cm housings on instead of 10cm's to bring power curve back to suit injectors instead of upgrading injectors... would be nice to see what they could pump out with some 1600cc injectors and 30-odd psi.....
Edited by URAS
Any specs on Athids TDO6 L2 20G Trent i.e. Compressor/Turbine inducer/exducer sizes?
Would be good to form some sort of basis to compare to the Garrett offerings.
Cheers,
i will post them up a bit later today for you.
I'm pretty sure Nigel from Ice Performance ran the same set up on his Supra, and to the best of my knowledge was the first RWD import to run 10's in Australia with a manual on radials, 10.91 from memory.
Edited by pepe lopez
Sorry to go off topic but what ever happened to the ICE performance r33 gt-r? They had some big achivements with power a few years ago and built some nice cars... now where are they?!
/On topic.
lol nigel shut up shop and ran to queensland after everyone worked out he was a shifty c*nt
PS - mad props on the big hp supra.
PPS - does it chirp second?
Edited by VB-
The ICE R33 GT-R is Leewah's car and its still around.
DAMN made 575 at Autosalon on race fuel i believe.
ICE closed a few years ago...Nigel started another shop which died in the ass. VB- is spot on with that one! And Gerald is travelling overseas.
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
