Thinking about adding variable cam timing to my next GT-R. I know HKS had the V-cam setup, but does anyone know if VCT from an RB25 Neo can be adapted to the RB26 head?
Anyone done it? What's involved?
yes it has been done...ive seen it and been in a car with it...amazing results.
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4486043
Okay so what about using an RB25 Neo head, on an RB26 block and adapting the individual throttles on the Neo head and a big single or even adapting the twin manifolds to the Neo head? I actually have everything to try this, really has me thinking now. I have a damaged RB26 engine and an extra RB25 Neo head. Just a couple of questions but I will still check it out, will I have to bore the bolt holes in the head to allow for the 26 headstuds? Anything else will I have to mod or it should be fine?
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4486498
The only difference is the manifold bolt up pattern but guys like ShaneF can make the adaptor plate for you and has done so with the 26 plenum on 25 head.
You will also have to externally feed oil into the vct like the RB30 guys do. But yeah, that would be the most practical way to do it. Both 25NEO and 26 heads have the same flow potential but the camshafts specs are different.
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4486522
I am almost done with the indivdual throttle setup on the Neo head, did like GTS4WD and changed the bolt holes and retapped, just need to alter the water neck on the throttle setup to accommodate the VCT solenoid. We'll see how it goes. Yeah may be a little wild but what the heck.
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4486548
before you go too far, the combustion chamber in the neo head is smaller than the rb26 head, so that would bump up your CR. I would get the neo head cc'ed first to see how much it will jump up, otherwise sell the neo head and get the normal r33 rb25 head and use that since it has the same cc's as the 26
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4487476
I believe it could be done quite cheaply, using external solenoids and 2 rb25 intake camgears using either head, however it isnt VCT by any stretch of the imaginiation, and tuning two switch on/off points could be time consuming. You may then have to go away and modify the vct mechanism for different angle throw. IMO if you are going to go to all this effort it would be worth investigating a different mechanism say off an evo or mx5, and get true vct, as dirt said the results would be very worthwhile
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4487511
Maybe I can run a thicker headgasket to compensate for the higher CR? Ideally would be to get it CC'ed.
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4487918
You would need to run a external oil feed to the head for vct, as the RB26 / RB30 block do not have the oil feed in the block to supply the vct.
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4490043
I found this a workshop in Japan that does NVCS Conversion in RB26 while trawling around on gtr.co.uk forums.
http://www.rising-web.jp/03works/03works_frame.html
Look like it was taken off RB25 to me. And from what I've read above comments, it's more than what it is.
What does it need to have one implanted to a 26, looks to be interesting way to gain power and torque.
Would your average Power FC be able to 'control' the NVCS seeing RB26 doesn't have one?
Is it possible to copy the data on NVCS from RB25 and program it into 26 PFC?
Or better get other ecu that already has the software to support variable timing?
Is it worth going all the trouble for?
Cheers
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4491992
I came across this conversion too a while back and it showed some of the machining, head modifications to the oil galleries to hook up an external oil feed etc. They used an inline solenoid to supply oil from the oil pressure sender line to valve, and then used a RB25DET intake cam and gear.
I cant find the pics, but they used a -4 oil fitting screwed into the front of the head and then had drilled galleries to supply the cam gear.
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4492545
Delphi make a cam phasor for belt driven camshafts - as used on the EVO9. You could probably adapt the solenoid from the EVo9 as well. Remember that full cam control is a bitch for most speed density sytems and that total "bump and check" cam phasing is alot of work for not much gain. Your better off with just an on and off cam advance solenoid
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4494691
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
