this is very interesting. what sort of bottom end improvement could this yield on an RB26?
http://www.skylinesaustralia.com/forums/Rb...html&st=200
Some bloke gives away a secret if you read page 11. It has obviously been done but how and also how to do it reliably.
https://www.sau.com.au/forums/topic/261777-rb26-vct/page/2/#findComment-4496613
  • 2 years later...
This is interesting, any info on how to go about incorporating VCT into a 26?
Paul from Red R Racing has had something available for a while now having VCT on the RB26 head; simple and cost effective solution from what I have seen. One of his Stage 2 heads with VCT would be a total animal with the right turbo combination!
https://www.sau.com.au/forums/topic/261777-rb26-vct/page/2/#findComment-6089968
  • 8 months later...
There was a more recent post on VCT for the RB26 head but I can't find it now. The link further back in this thread doesn't work. Does anyone have a chart showing the curve for an RB26 with VCT switched on and off to compare? It seems ERD and Red R Racing have developed a VCT system for the 26 - does anyone have prices for a completed head or for conversion of a supplied head? And is special ecu software required or will most aftermarket ecus such as Link/Vipec and Motec be able to run this OK?
https://www.sau.com.au/forums/topic/261777-rb26-vct/page/2/#findComment-6450070
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=msg&attach_id=364854
That's the link to the dyno graph I PM'd someone here. The runs were done one after the other on 10psi boost on a bush bearing T04Z. We still hadn't done a larger inlet cam at this stage so the spec on the inlet side were roughly around the 245 deg advertised x 8.3mm lift. The car has a larger inlet cam in it now which has improved the response slightly but the wheels have changed since then too so I can't do a comparo from the baby cam to the new one
https://www.sau.com.au/forums/topic/261777-rb26-vct/page/2/#findComment-6450089
The Green line is VCT off and Blue line is VCT on.
Also when the boost was increased to 30psi, the response gap between the two is larger. The VCT switching point should be just prior to the line intersection and it will follow the higher line but your tuner should know that already.
https://www.sau.com.au/forums/topic/261777-rb26-vct/page/2/#findComment-6450290
The real world gains in advancing inlet camshaft timing at low to mid engine rpm far out ways the given gains in the displayed dyno graph but it does clearly shows the result of net losses if cam timing is left in the advanced position
https://www.sau.com.au/forums/topic/261777-rb26-vct/page/2/#findComment-6454097
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
