I dont believe Nissans are "thrown together" as KiwiRS4t infers. Local Subaru dealer complained that Nissans are "Bullet Proof", especially those from Factory 5.
  • Replies 45
Just going back to something mentioned on page 1 about aftermarket ecu's and the auto, Haltech e11v2 does NOT control the auto or receive feedback from it at all. Speaking from experience here :D
Edited by bubba
Yep not complaining about the build quality Hugh, having just pulled one apart I can tell you that they are very well constructed but some parts are R33 some S14 some GTR etc. I have just got a copy of Fast and will have to learn how to use it to make it easier to track down parts.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
