Heyy
Before I ask, yes I've done the research and looked through about 20+ past threads on this question. I've still been unable to find a solution so now im here!
I've got a stock r34 NA exhaust and I want to upgrade to a new system.
I'm not particularly after more power, but rather a nicer tone. However, I don't want to lose power/tourque so a 3" system may be out of the question.
What advice can you give me on a 2.5" exhaust system to get. Where can I find one to buy online? I looked on nengun.com but they didn't have anything. I've considered going to my local exhaust place and getting a custom 2.5" system made up, but I would rather get a quality system (HKS, xforce, blitz etc). I'm after a deep tone with minimal drone with an awesome sound at high revs.
Sound level? Well i'd like to get a silencer but without silencer nothing over 100db
What are my options?
Thanks
Dom
https://www.sau.com.au/forums/topic/261791-need-exhaust-advice-for-r34-na/
Good luck with finding an aftermarket to suit 2.5" N/A. The only one that I recall seeing marketed for the N/A was a Fujitsubo Legalis R catback from Just Jap. It's marketed as being for an N/A Sedan, though this doesn't confirm the pipe sizing. AFAIK the coupe and sedan catback is the same.
http://justjap.com/store/product.php?produ...=273&page=1
TBH at $1199 +shipping, you could get a very good quality catback system with a good quality and nice sounding muffler set up and hi-flow cat. Add a few hundred more and you've got yourself extractors, cat and catback.
You mentioned that you're not so much after power but rather a nice tone... to be honest if you're prepared to spend the sort of money that aftermarket systems cost, I know I would be wanting more power out of it.
A larger diameter exhaust on an N/A will be louder. The characteristics of an N/A means it's going to be louder as the turbo helps muffle the exhaust.
Just change the rear muffler to get a nice tone, and make sure it's not an el cheapo one that will just make a loud noise and sound bad...if all you're after is a nice tone and not a power increase.
I have one of the Fujitsubo Legalis R systems on my car ( courtesy of the good people at Just Jap ) and it is the only name brand / bolt-on system I could find for an R34 N/A sedan. I "think" Kakimoto make a bolt-on system for the R34 N/A coupe also but you're best to confirm that with Just Jap. FYI, the Fujitsubo Legalis R system on my car has a similar sound to a BMW M3 and the longer you use it, the better it sounds ( as the muffler guts settle ).
But as N-DAWG & Reggi34dr said, the most cost effective way to go is a custom made system but the trick is, finding someone who REALLY knows what they're doing. So many people drive away with a system that looks "OK" & sounds crap and end up going back and getting it chopped up to insert a different resonator etc. and still drive away only sort of happy.
If you're going for a custom system and flow & tone are your main objectives, I would recommend the following.
Get a Cat-Back system made using 2.5" mild steel ( mild steel always sounds better than stainless ). Make sure it's madrel bent ( not press bent ) and get a large high flow ( but low profile ) cross flow resonator fitted where the factory one was, and the rear muffler should be a big, high flow straight through muffler. This usually provides the deepest tone with the lowest cabin noise and should be around the 93-98db range depending on what products are used. Don't forget to either paint in with high temp paint or ceramic coat ( will make it sound even better ) it. It will sound a bit quiet for a while but will develop the right sound in time.
Oh, and as soon as you remove the pea shooter factory system you will find the bottom end torque will dissappear no matter what, but will simply move the torque up closer to the mid-range. Also, your mid range & top end power will increase a bit with a bigger system but don't expect too much.
Anyway, that's just my 2 cents. Hope it helps :P
And one more point, Coupe & Sedan Cat-Back systems are not the same. The sedan system is longer.
Anyway, that's just my 2 cents. Hope it helps :)
[/qu
_____--------------------------------------------------------------------------------
Kakimoto do one - I have a Kakimoto Super Race system fitted - see pic - came with car from Japan - meets legal post-57849-1237496176_thumb.jpgoise criteria
I dunno about bottom end torque disappearing - thats a very big overstatement imo - car still pulls strong even in 5th from as low as 60kph and if you occasionaly pick up 5th from second - not impossible to do as the gating of the gears is not so precise in Skylines and most jap cars - you really don't need to go back to 3 rd in most situations - with the bigger exhaust you certainly get a rush effect from about 90 kph+ in top or in any gear after about 3500+ revs but I think this is more to do with the extraction system and valve timing effects at the higher rev ranges
if you can find one at the right price I say get it
Yeah, "disappear" is a bit strong, but the change is very noticable from take-off.
Oh and Kakimoto actually make 2 dedicated systems for the R34 N/A Coupe :P ( and none for the sedans :down: )
Thanks for all the replies guys.
I went with TokyoTaxi's suggestion.
custom built 2.5" mild steel. Mandel bent, high flow car, high flow resonator and high flow low profile muffler with 4" tip.
Here's a before and after vid:
Sounds mad ! I love it and by the thumbs up at the end I'm guessing you do too. And as everything settles in etc the sound should get even better :devil:
Should sound good under load too. How's the sound from inside the car on the road ?
  • 3 weeks later...
Sounds horn :)
If your simply after a nice note, STAY AWAY FROM GENERIC BRANDS!
I have a NISMO exhaust and I frequently get comments on the note. I wish I had a video, cos it sounds awesome!
Brand name products are the way to go
whats cabin noise like? sounds tuff tho, you did well
Very sxc exhaust on that 34.
Ive gone with a 2.5 inch mild steel mandrel bend...picked up a second hand muffler....does affect sound, but Im not too fussed. It sounds pretty good. WIll youtube one day.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
