Fellas,
My RB25/30 build has recently finished with my GT35R.
Just wondering, of the top of your heads, how much will it cost for the piping:
1) To fabricate the dump pipe, and plumb the external wastegate back to the exhaust piping
2) Fabricate intake piping from turbo to Z32 afm which sits near the front left head light
3) fabricate intercooler piping from my plazmaman plenum to the cooler piping (about 30cm) and from the turbo to the other side of the cooler (about 50 cm)?
4) take of the cat and place a 3.5" straight pipe
I astimated about $800 for everything, would I be correct in saying this or do you fellas think it's going to be more?
https://www.sau.com.au/forums/topic/261814-need-advice-on-price-for-piping/
800-1200 depending on material and sillicon choice. Make sure to put a flex joint in front/dump and one between gate and front dump...... saves cracked manifolds down the track if you scrape a speed hump, kid or Neighbours pet.
Edited by URAS
lol AT IF YOU SCRAPE A KID!!!
yep that price sounds fair. 2nd the flex joint. just fitted one in mine around 250mm off the turbo 3 in diameter by around 4 inches long. should take a load off the manifold and add a bit more 'give'
