Im getting sam problems Stalling when stopping, Hitting around 5000rpm car feels like its dying no fuel / to much air!
got a new High flow on it running 1 bar.
Just bought a SAFC / Fuel Pump for a tune hope it works.
Sounds like you're hitting R*R.. 1 bar through a hiflow on an untuned stock ecu.. hello rebuild :down:
https://www.sau.com.au/forums/topic/261816-fuel-pump/#findComment-4495211
Installed my SAFC last night, tune on monday,
actuator is D/C
Well at the start get the car dyno to see what psi it was running it was at 24psi lol
So re-connect boost line to stock * then placed on my bar.
Air was ok Had new Sparks Place the guys put thos New Tips ( which i think already blew so going to try NGK's
Checking AFM and Fuel Pump also Coils this week .
Edited by RICCA
https://www.sau.com.au/forums/topic/261816-fuel-pump/#findComment-4495524
24psi?!
When you disconnected the actuator did you just pull the hose? or disconnected the arm from the flap?
Are you saying that with the actuator disconnected, it's still running 1bar?
As for sparkplugs.. NGK BCP6ES-11's, gapped down to 0.8 if needed.
https://www.sau.com.au/forums/topic/261816-fuel-pump/#findComment-4495609
Did you mean disconnect the waste gate actuator so that it is always open = car will run max boost of like 6psi at full rpm, cause the gate is always open. Or disconnect the hose so that the gate stays closed and runs max boost ~ 24psi....
https://www.sau.com.au/forums/topic/261816-fuel-pump/#findComment-4496860
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
