Im getting sam problems Stalling when stopping, Hitting around 5000rpm car feels like its dying no fuel / to much air!
got a new High flow on it running 1 bar.
Just bought a SAFC / Fuel Pump for a tune hope it works.
Sounds like you're hitting R*R.. 1 bar through a hiflow on an untuned stock ecu.. hello rebuild :down:
https://www.sau.com.au/forums/topic/261816-fuel-pump/#findComment-4495211
Installed my SAFC last night, tune on monday,
actuator is D/C
Well at the start get the car dyno to see what psi it was running it was at 24psi lol
So re-connect boost line to stock * then placed on my bar.
Air was ok Had new Sparks Place the guys put thos New Tips ( which i think already blew so going to try NGK's
Checking AFM and Fuel Pump also Coils this week .
Edited by RICCA
https://www.sau.com.au/forums/topic/261816-fuel-pump/#findComment-4495524
24psi?!
When you disconnected the actuator did you just pull the hose? or disconnected the arm from the flap?
Are you saying that with the actuator disconnected, it's still running 1bar?
As for sparkplugs.. NGK BCP6ES-11's, gapped down to 0.8 if needed.
https://www.sau.com.au/forums/topic/261816-fuel-pump/#findComment-4495609
Did you mean disconnect the waste gate actuator so that it is always open = car will run max boost of like 6psi at full rpm, cause the gate is always open. Or disconnect the hose so that the gate stays closed and runs max boost ~ 24psi....
https://www.sau.com.au/forums/topic/261816-fuel-pump/#findComment-4496860
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
