Ok, I have a whole heap of gear for sale. I'm going to make it very clear: I DO NOT WANT ANY OFFERS - ALL PRICES ARE FINAL. All of this stuff is being sold below what I paid for it. I am located in Cremorne, Sydney.
1. Billion CAI - $90
75mm model. Unused. Costs well over what I am asking to get it imported from Japan.
2. Full set of Trust/GReddy gauges - $400
-Trust Boost Gauge
-Trust Oil Pressure Gauge
-Trust Oil Temp Gauge
-Trust Sandwich Plate (brand new)
**Can also chuck in two 60mm Trust gauge stands, for an extra $50. These are brand new.**
All senders/sensors/etc are included. All gauges are 60mm. I bought these from Yahoo Japan and all were reportedly working. I will not separate the package, so do not ask.
3. ARC Turnflow FMIC - $200
I'm pissed off about this one. Purchased from a sponsor, only to find that it appears to be for an S14 and thus the piping doesn't fit on my S13. With some mods it would fit an S13 - maybe an extra pipe. This is the cooler where you don't have to cut the battery tray, it lines up to stock piping next to the factory airbox position. The core has a dent on the bottom, nothing too major, and a few bent fins, but it only matters if you are a ricer.
I want to make it clear that this WILL NOT fit an S13 unless you get some little bits of extra piping made up, and it SHOULD fit an S14, but as I have not tried to fit it to an S14 I cannot guarantee that it will fit.
4. AURFA Boost and Oil Temp Gauges - $60
Only months old, barely used - were wired up into power but the sensors hadn't been installed. Still have original packaging. Comes with sensors too.
5. S13 Silvia Aero Rear Pods (Copies) - $150
Brand new, painted Nissan black (KH3). Unmarked, unfitted, these are fibreglass and I paid a lot to import them from Japan.
6. S13 Silvia Aero Rear Pods (Copies) - $120
Near new, in white gel coat. Excellent condition.
7. S13 Silvia Vertex Style Side Skirts (Copies) - $100
Perfect fitment, painted some kind of matt black or blue. Only issue is one small crack on one of the skirts and a rough edge on the other. However, it would be an easy fix during prep.
8. R33 GTS Front Brake Package - $350
Bolt on upgrade for an S13 Silvia. Includes:
-R33 GTS calipers
-DBA slotted rotors
-Pads (not much meat left)
9. Turbosmart Vee Port Type 2 BOV with Turbosmart Hot Pipe - $150
Only six months old. Purchased brand new, atmospheric BOV, literally a five minute bolt on job with stock S13 cooler piping (as the Turbosmart Hot Pipe is included).
PHOTOS
Billion CAI
ARC FMIC 1
ARC FMIC 2
Trust Gauges
AURFA Gauges
Side Skirts 1
Side Skirts 2
Side Skirts 3
Aero Pods
R33 Brakes
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
