Twin Turbo 350
TwinTurbo350
 Share
Sorry if this is the wrong place to post,
Hi all i'm new here so here goes....
For the last year, I have been in the process of building my track/race 350z 2006 with all of the driveline, VQ38VHRTT from the new R35 GTR Jap spec halfcut from Japan.
Painstakenly the engine, twin airboxes and all of the wiring has been fitted and bolted under the hood to keep the car looking stock as possible. All of the rear diff, transmission and suspension have been welded/fitted and bolted in the rear end from the halfcut I imported from japan 2008.
When I recived my shipment from japan most of the parts were missing! Critical parts like the ECU (needed to run the gearbox and quick launch) front Seats, steering wheel are all gone. Apparently now my biggest problem is (which i found out last night talking to my mechanic) that I cannot use my Motec m600 to run the car according to him the car will start but not drive as the whole ecu controls the transmission. I have read posts from here and see you guys are the ones in the know! What should i do? Wanting the car to look stock but packing punches, how can i get it to start should i buy a new ecu immobiliser keys? anybody have japanese sources for parts?
how much would this All cost? any help is much appreciated.
Not sure many people will be able to help you out. You are definitely treading on very unknown grounds there mate :sweat:. I know work on the R35 ECU has been going on but as for running the engine out of the car.. wow :). Photos?
I am in Australia, my mate from Queensland did most of the dropping in the engine welding and fitting in his garage at QLD for 3000 !
the parts were very expensive though. I will definitely take some photos with my mobile when i drop the exhaust off. anybody have a Zele modded ecu in there R35? how much do they go for ?
One of my mates does, dunno which one he bought though
type 1 is 4Gs, type 2 is 3Gs
It's worth it but seeing as how I'm sure with all that power you certainly don't want to be speed limited...
The car will be used for the strip so speed limiting will definiely out of the question, gradually as the engine receives mods and turbos ect.... down the track would like to have a ecu to handle the change. For now I am looking at getting her running and engineered for registration purposes.
Send Haltec an email, I know they where working on a gearbox control when everything went a little pear-shaped.
Have you also thought about old-style H-pattern gear selection and custom parts, might be something else also to think about.
As for everyone wanting pics, how bout help the guy, then ask for pics :down:
B.
it sounds like bs.
x2
The VQ35 is a great engine to start with. Wouldn't it be easier just to stroke it bolt on some turbos and put a holinger behind it?
It would be alot less hassle. Not as interesting 'pics' wise, but easier.
Besides, it's not called a VQ38VHRTT. I reckon if you'd gone to all the trouble of sourcing it and sticking it in the car you'd know the correct engine designation. And you wouldn't normally get front seats in a half cut, and definately not a rear mounted transaxle gearbox.
Sorry mate, it's nothing personal, just that a few things don't quite add up.
However, if you are genuine, then good on ya mate for doing something different, and if the pics do surface, then I'll eat my hat.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
