Hi there i tried a search and couldnt get any good info, i am looking at buying some castor and camber arms for my R32 gtr and not sure what a good brand to go with.
I also have heard that i should get fixed camber arms not adjustable is this true.
can anyone give me some good info please so i can do it right the first time.
cheers,
Dave.
All depends how much adjustment u want. For street just aftermarket bushes are good (Whiteline etc), but they dont offer a whole lot of adjustment.
For track work i would go Adjustable. Ones like Cusco, Ikeya Formula are very strong and offer a wide range of adjustment.
I have basically Cusco's whole range under my car and cant speak highly of it. Have never had a problem with it.
Thanks for that info i have been doing alot more research lately and yeah i have been told the same.
I will go the adjustable castor and camber arms to get it right as i will be doing some occasional track work, i guess you might as well spend a little more once than doing it right a second time.
I will look into the cusco and ikeya formula brands for pricing, anyone have any of these that they dont need anymore i would be interested in purchasing them.
  • 1 month later...
hey mate, i have adjustable front camber arms on my 32r, i bought them from just jap, $415 deliverd, in1 day. tey appear to have roller bearings at the pivot points. seem really good for the cheap price. cheapest i could find, and look pretty shmik too...
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
