just got my sump back from being glass beaded and well it has turned out great modded it to have extra capacity by chopping the box section of the existing sump out and welding a new hollow section in and repeating the process for the other side and i have also fitted new studs to it and a tomei sump baffle should help in combating the rb26's oil hiccups well here's hoping
https://www.sau.com.au/forums/topic/261904-custom-rwd-rb26-sump/
yeah where the front diff was cast to the sump it had cracked through a little so it need re welding and it had pulled the sump wall down prob 2-3mm so we had to build up the weld in the dropped areas and then deck the excess off till it was all flush again but has pulled up alright wont affect it in any way so what your seeing isnt that the section in question is lower its all the same height just without the gasket grooves in it
Looks nice, we had a similar problem welding my rwd rb26 sump and had to face the flange...(note to self - bolt the sump to an old block next time)
btw did you source the studs/bolts from nissan? Was a pain getting all the part numbers, waiting for some to come ex japan then half didn't fit anyway.... ended up using rb30 exh manifold studs in places lol.
yeah thats all i used rb30 manifold studs same thread and only 2-3mm longer did the job perfect and yeah bolting the sump to a block would have worked next time (im hoping there wont be a next time) i would also go down that path
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
