ok so i thought it was auto but after taking it to a shop and then ingeniously putting it in P and still wouldnt rev past 4-4500 we came to the conclusion some thing motor related is wrong, now im going through a process of elimination so far i have done TPS. next will be AFM but im starting to think possibly fuel reg or pump, possibly even exhaust blockage, it has always been hard to start cold, as in it wil fire 1-2 cyl at a time till all 6 fire up over about 10 secs.
the car is a cima with vg30det and front mount with stock exhaust, think cat may be hollowed out
ps when it revs it has no power its not like it cuts out its like i am towing a elephant and then stops at 4ish some times more, when it goes over 4 to like 5-6 it back fires loud
Edited by E-Z
https://www.sau.com.au/forums/topic/261953-engine-doesnt-want-to-rev/
I had the same problem with my R32. Around 4-5k it would start popping and backfiring. It turned out to be my coil packs. I sealed my coil packs up and then the car was fine after that :D Or you could buy some new ones. If that ends up being your problem
yeah i thought it was cooler aswell, i have re done it all and seems to be fine, could be coils i suppose but it doesnt mis fire and it makes boost and holds it, it only pops if i hold it down to push past 4k
put in new .8mm gap plugs and good working coils to no avail. advanced the timing to max and it works better but only runs 5 psi max now. my mate who is a bit of a guru think i might have slipped some teeth on the timing belt on some of the cams. it now hunts on idle and has a idle miss, im thinking thats just the .8mm plugs. going to pull the timing covers off and see if it all lines bak up. any other ideas?
Pretty strange that it will make "full" boost in neutral.. my guess is like your guru mate, it may have slipped a few teeth and the resultant retardation is aiding it in building boost (like launch control..)
well timing belt looks like it had a bolt fall in some how :down: it was thrahed im suprised it hasnt broken, i had a spare belt and chucked that on,. but the old belt was still doing its job, all timing marks lined up, im thinking maybe it has something to do with vct? could that be retarding the timing or something? car is pretty old and most wires are brittle. im going to check fuel filter and put a guage on to check pressure, car just seems really od,
thanks ryan
yeah so there was a bolt sitting in in the crank case cover wearing the belt, but that wasnt the problem, so i replaced the belt anyway cos it was dodgy, and i found a big as vac leak from line which had popped off, that fixed the idle problem, and i cleaned the aiflow meter witch some metho. but it strated working better before that, so i actually dont know what fixked it, i think it could have bee that other belt was really streched but yeah, auto is shifting really fast into third, like 123 at 30kmh but i have been told thats just a tps adjustment. but im not entially sure it is fixed i guess time will tell. also what i done was put a one way valve in the fuel reg vac line so it will only see vac no boost as my car blows alot of black smoke on boost (before any of the previous problems) this is a remedy i read in a HPI magazine saying its a common over fueling problem and that will help. can any one confirm or any one disagree?
thanks heaps everyone for your input :3some:
Ryan
ok i had a similar problem, i cant exactly remember how i fixed it but it was around the time i was installing my boost guage, now i think it was running lean, and it popped and carried on with no power output, you should check the mixture?
yeah yeah whitey haha i have already spoken to sean, if i have any more dramas its getting a v500 and manual valve body but untill then i would like to enjoy the car for a while without pyromania thoughts, which reminds me i should get fire and theft on it..
thanks heaps everyone for your input :down:
Ryan
That's fkn dodgy as.. I'd get it on a dyno ASAP as it's mostly likely running dangerously lean at high boost/rpm.
would i not hear it ping? yeah i might rip it out, it does say to have it checked on a dyno. well car is 100% again. from my conclusion it was cam timing from stretched belt, mixed with bad spark from coils and plugs, also my funny shifting patterns were due to a faulty TPS put the original one back on and all good, thanks everyone :P
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
