im cleaning out to move to WA i brought 4 r33 wrecks to make 1 good years ago when they where worth alot more then they are now never made a good so i got shit loads of stuff sitting around collecting dust and taking up room
here as a list of stuff i can remember thats is there
ALL MUST GO MAKE ME A OFFER
r33 gtst s2 stuff
r33 s2 complet interior everything including air bags, keys, locks the lot
silver boot and spoiler paint bit chipped $100
black spoiler with led $100
r33 gtst s1 stuff
rb25det motor had head work done no turbo ecu & loom $1500
rear seats x2 $20 each
dash pad with all vents $50
cluster surround $50
rear garnish between tail lights x2 $40 each
wiper motor front and rear $20
drivers side door in white paint bit chipping $60
boot carpets and surrounds
lhs tail light in wine red $50
stock wheels
space savers x5
door handles
wiper bottles
over flow bottles
egine loom $200
car wiring loom
sliver roof cut for a roof repair $200
Stock turbo maniflod $80
wine red rear cut good for one some in need of rear end repair $300
also have
R34 bonnet in a purple color $250
GTR Stock dump pipes $60
Tuned R32 Gtr ECU $200
Thats only what i can think of so pm me with some thing u need i may have it
make me a offer on price or the lot i need it gone asap
pick up bendigo vic will post anywhere if u pay
pm or call 0424897340
hey man if you have a good condition series 2 gear knob or if the series 1 is the same could you please send me a picture? pm with price please!
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
