Make/Model: hr31 coupe
Year: 1987
Kilometers: 187 229
Transmission type: rebuilt manual
Engine: rb20det
Colour: gunmetal grey
Modifications: turbo timer, bleed valve, cat back, vg30 turbo, nismo 6 spoke forged wheels
Roadworthy Certificate: no
Asking Price: $5000
Contact Details: 0424897340
Will get some pics as soon as i can
Is red top NICS or ECCS? Swap + cash for 87 gx wagon. 145kms on clock. Has had full fluids, filters, plugs, dizzy cap, button, leads, coolant + all hoses, thermostat + housings, water bypass pipes and auto trans cooler fitted within last 6 weeks?
Mate, I am just an annoying punter, but some interior pics and engine pics may help to move this bad boy; it looks great from the outside and the price is right...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
