hey all
as some of you might of heard, in very unfortunate circumstances my sil caught on fire and melted a engine loom, and long and short of the short is it cracked a ring glan and then went down hill from there... so the poor lil 20's days are over :(
but from bad comes good....
and has finally given me a excuse to a RB25/30 :P
so here is what I have so far for the build...
(only started collecting parts only bout 1-2weeks ago)
- RB25 S2 Head
- RB25 Loom
- RB30 S3 Bottom end
- ACL Race Main Bearings
- ACL Rod Bearings
- ACL MLS Headgasket
- 2x Tomei Oil Restrictors
so this is now whats on the to get/do list:
- Boring, Blueprinting etc... on rb30 bottom end
- Arais Forged 20"tho Oversized pistons
- ACL Race Rings
- "x" Forged Rods
- Tomei Pro Cams (264 inlet, 272 exh)
- Stronger Value Springs
- ARP Head Stud Kit
- ARP Rod Bolts
- CNC billet rb30 crank collar
- assorted earls fittings and braided hose
- CNC Powertune RB30 Oil Power gearset
- Gates Timing Belt to suit 25/30 combo
- Custom Oil Drain
- New Water Pump
- Send my turbo back for the new one :D (GT3076R .84r)
- 50mm ext gate (currently running a KKR 38mm)
and thats all I can think of so far...
aiming to have the donk done by june-july... as there is a fair bit of coin right there haha!!
but 3 or so months anit long to wait :)
but if you have any suggestions fire away!!
cheers
Benji
Edited by Benji
https://www.sau.com.au/forums/topic/261976-benjis-new-donk-build-up-2530/
N1GTR: hitting the streets on permit that is, since mine is a track car!!! :P:(
I enjoy the old permits tho!!! its great fun!!
doing a CNC billet set of oil pump gears that are custom made to fit the std pump surround... but the gears itself are alot stronger and better..
and yes ill be doing a enlarged sump as well...(its similar to the high energy style ones)
and have had a chat to my engine builder and have decided to go with 40"thou oversized pistons, which brings it to 3.1ltr :laugh:!!!
and we are going to piss the vct off as well.. n run some tad smaller cams... and some adjustable cams gears as well
here is a pic of the car when it had the rb20 in it..
(mine is the blue s13.5)
Looks like a great build, i would recommend running an external oil pump, and dry sump it or rear sump it so you can lower the motor.
yeh i would love to run a ext oil pump but its the cash,
donk will fit in sweetly man... just wait and watch what im going to do when the time comes to slide it in...
nice car mate. i guess u drift it? cant go wrong with the rb30's for sliding my 2nd one is in progress aswell
awesome this means i will have 3.1 litres aswell. theres no replacement for displacement haha
yeh started to slide man, only been out 1 n a 1/4 times on the track
and was just starting to get a grip of things then the mis-happen of the engine loom melt down..
oh well now the power will be nice and responsive and will be easier to steer without having to be trying to bring it up on revs...
Edited by Benji
good work mate, i have been for 3 years now haha. i cooked a loom too when my engine blew and oil seal and caught fire on the track. you definately will have more response form the 30 vs the 20 it will be a big difference you will love it.
picked up ARP Headstud Kit today,
next week, the full forged SCAT rods, and 40" over sized Arais Pistons + Arais Rings,
Gates Belt Kit, and my Extended Sump... will be in :D
then after have got all them,
can start to put together the bottom end in the next few weeks
then we are away n cooking with gas :P yay!! : :hypo:
Also awaiting to hear back on the price of my Tomei Poncams + springs... (264deg inlet/exh),
once I know I can order away :)
so getting there at a steady rate now :P
  • 8 months later...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
