Hi All,
I have a Xtreme Heavy Duty Clutch Kit Brand new i purchased the wrong kit for my car this is a push type please see link:
http://www.tweakit.net/shop/product_info.p...roducts_id=4430
$400.
Located in canberra
Cheers
Paul
https://www.sau.com.au/forums/topic/261994-xtreme-heavy-duty-clutch-kit/
